View Poll Results: Please check all items that you need to work on at the Maintenance Meet. | |||
Interior lights (specify in post) | 6 | 54.55% | |
Exterior lights (specify in post) | 0 | 0% | |
PCV Valve | 2 | 18.18% | |
Oil and filter change | 2 | 18.18% | |
Transmission fluid change (partial change) | 0 | 0% | |
Power Steering O-ring fix | 5 | 45.45% | |
CV joint boot inspection | 3 | 27.27% | |
Headlight polish and care | 6 | 54.55% | |
Adjust tire air pressure | 1 | 9.09% | |
Air filter change | 0 | 0% | |
Air conditioning system check | 4 | 36.36% | |
Paint wheel center caps (specify year) | 3 | 27.27% | |
Torque lug nuts | 3 | 27.27% | |
Detail work (wash, wax, and dent removal) | 3 | 27.27% | |
other - (please specify in your post) | 1 | 9.09% | |
Multiple Choice Poll. Voters: 11. You may not vote on this poll |
Thread Tools | Display Modes |
he he Darn no secret projects!
I've talked to David (I think it is) the guy that makes the SVX stereo wiring harnesses, from time to time about the LED dash project, he is still working on it, slowly. I've never had the dash apart to see the bulbs, but I always heard they were just tiny little bulbs, but not actual LEDs. Could be wrong though, something that small would almost have to be a LED anyway right? The theory with doing LED's everywhere being that it would be easy to do alternate colors, be brighter, use less power (for whats that worth), and last forever.
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
If any one needs directions to my place where the meet will be, email me so I can attach the directions and send them to you.
Earl, i need
1) lights across bottom row of dash (fog/flasher/defrost/etc) 2) paint 92 center caps 3) polish/de-yellow-ize headlight covers 4) help in programing new(for me) remote/security system 5) also- my cruise control doesnt work, although you can hear someting being activated when you engage the lever on the steering wheel. it may be too much to deal with at the meet. but any advice will be appreciated. thanks for hosting this. |
For the tire pressure thing, can we do the whole measuring the diameter with someone in the driver's seat?
I also have a very good idea what is wrong with the cruise control. Check to see if the vaccume line has come off. That is a very common problem that is easy to solve. Hope it is that and you can use it when you come over. If not, we will look at it.
The whole measuring the diameter thing?
i need help with my security system too, i don't think it works but i have a remote and someone who has already done the programming on another car can confirm im not doing it wrong.
I also need directions. |
Tim
I will send you direcitons. You will get them if your email address is the same as it has been. If not, send it to me and I will send you directions and a light replacement list. Troy I will talk about the rolling diameter thing that day. You may Believe it or Not.
I now have a list of the numbers and lights so you can figure out what lights you need for the meet in my locker under the folder "Lights".
That way I don't have to email each individual, not that I wouldn't. Just easier. If you need directions, contact me or Troy, and we will get them to you.
Just to confirm for the record...they are not LED's in the dash. They are in fact mini bulbs shaped similar to LED's. The best way to realise this is the following: You can dim these bulbs with the dimmer adjustment. You can't dim LED's.
Thanks for the clarification.
#28
I need someone to show me how to grow hair on the top of my head. I think Earl will sign up for this seminar too.
Larry (folically challenged) III |
#29
Where can I sign up Larry?
#30
