The Monzta '96 Subaru SVX (111K) - UK spec '85 Opel Monza GSE (71K) '86 Opel Monza GSE (95K) '93 Toyota Estima Lucida (37K) - JDM import My psychiatrist says I'm suffering from paranoia........but he's always hated me!!! |
I have this SW! but can not use Printscreen function damn. I will try to uplode it to my locker and let all know. It has 380MB and I use GPRS connection at home...
Peter |
No problem Peter, your efforts are very much appreciated.
Here we go. This bloody thing does not support PrintScreen function in Windows XP so I have to take picture of my LCD:-))
Hope it will clear you how it is connected together. Peter |
Just forgot to mention it is for continetal Europe version MY 94 and UP. I can get file for UK version as well so no problem, just let me know...
Peter |
Hi!
I can supply you with a FTP space for that 380MB file (and others too). Aim your favorite FTP program to: ftp://svx:boxer@193.12.43.114/7551 with "passive" FTP mode, and your'e in. if you get the message: "Error 501 PORT Address does not match originator" then it is because you are "firewalled" in such way that my firewall thinks that you are trying to "spoof" the connection, and you are denied access. This is necessery and nothing I can do to avoid. I have initially set the quota to 2GB and a maximum of 5 users sharing 512kb/s upload and download speed. Last edited by Sonar; 12-17-2003 at 10:54 AM. |
Thanks so much for that. The diagram is very helpful. I can't make head nor tail of it at the moment but I'm sure ten minutes with a cup of tea will bring illumination. Does the one for the UK version differ in some way to the one you posted? I can follow the course of the water from the bottle on the left through the pipe to some sort of assembly. What is that? Is it another water reservoir? The smaller item just beside it (bottom left - part #86611) looks like a water pump. Where is that pump situated in the car? Is it easy to get to? I can't say I've seen one in the engine bay during my travels. And it still doesn't explain why I have a leaky tube coming back to the main water bottle. But, thanks to you Peter I know twice as much as I did 10 minutes ago. Thanks.
browser: ftp://svx:lsi@dcss.dyn.dhs.org/ FTP Client: server=dcss.dyn.dhs.org port=21 user=svx password=lsi
So guys I have download it to Earthworms FTP, Sonar could you move it to your server as an alternative site?
If any problem with instalation let me know, as for UK version, there are no data for SVX, only some Imprezas and Legacys.. Also no US data so use only LH setting at F3 Setting screen. Peter |
-Done
Internal name: "SuperSonic" -92 ebony black with 170k KM *** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. *** |
Do you have already installed it, went it OK?
Peter |
I can not connect to your FTP...
Peter |
#28
I managed to download it (from both sites) and install it, but I get an error when I try to run it. Maybe it doesn't work with Windows 2000. I'll install DOS on a spare machine and give it another go.
Thank you very much for sharing this software Peter. Phil. |
#29
It is definitely running under Widows 98 SE and Windows XP Proff. As Windows 2000 has simillar core as XP it should run with no problem. CD I have is not original Subaru, it is a copy. So please check what I wrote in .DOC file in the ZIP. It has to be burnt to CD exactly as unzipped (3 folders and 3 files in root directory; instalation should be run from folder Subaruex/setup.exe) It is (as for me, important to name the CD like I wrote)
In the settings window please be sure you check LH version and check weather drive letter of your CD/DVD ROM is the same like listed there... I played with instalation for a hour or so... One feature I miss is PrintScreen... Peter |
#30
My USA SVX has a headlight washer. However in order to use it , the car must be stopped and I must be outside with my water pistol and a clean cloth.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
