Old 08-31-2001, 02:38 PM
EveryShadeofBlue EveryShadeofBlue is offline
British Car Junky
Send a message via AIM to EveryShadeofBlue Send a message via Yahoo to EveryShadeofBlue
Question Brake Shims
I just got my new pads in the mail and I have brake shims with them. I've never used or seen these before. How are they mounted? I have shiny pieces of brake pad shaped metal and then some black pieces and then lots of gold clips. I don't know what to do with any of it!
Jeff
Jeff - Tampa, FL -
Old 08-31-2001, 02:41 PM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
they should all clip together in some manner
piston-shim-shim-pad-rotor
something like that, I think...
Kev
kevin.m.sheets@verizon.net
Old 08-31-2001, 02:54 PM
British Car Junky
I think the front pads have 2 shims on them and the backs have 1. I only have six shims. The shiny metal ones (I'm so technical) clipped on and I put a black one on the back of it. Then for the rear pads a black one just fit on.
Make sense?
Jeff
Jeff - Tampa, FL -
Old 08-31-2001, 03:07 PM
cocacola08's Avatar
sounds right, when I took mine off they were all rusted out and nasty. so I can't help with the colors. Did you get front and rear pads?
I think the way mine were, (I've only done the fronts) on the inside pads there were two each and the outsides had 1 each. But it's been a while and I don't really recall.
All I know is that I'll NEVER EVER buy bendix replacement pads for mine again.
Kev
Old 08-31-2001, 04:20 PM
Lowered SVX
i only buy carbon fiber.
although i think i will try the kevlar brake pads next because i have heard that they keep the dust level down. anyway good luck with the shims. i am not much of a do-it yourselfer. here is my $65 sir, thanks again and i will see you in six months.
"Too much fun to drive!"
