Just Venting
Well, just thought I would vent here.
About a month ago I found out that my A/C didn't work. The dealership told me "$300 and we'll look for leaks in the evaporator case" They had already pumped 2 lbs of r-12 in and it leaked right out. That cost me $200. I got ripped off, never mind having to drive 60 miles each way to a Subaru shop. Debating over the thought of spending the $300 I went down to a local shop (Chev-bro-lay) and asked if they could do a leak test. They said "Sure. Our labor rate is only $45." They did the leak test, charged me $24 and said "Yup, it's the evaporator" SO. I get a used evaporator from a parts yard in Virginia for 50 bucks, install it myself (there was no r-12 in it anyway) and took it back down (today). They vacuum check the system, and all looks good. They start pumping in the r-12 and......blow out the compressor seal. They lost 4 oz of freon and don't charge me a thing. Well.....found a used compressor in-state for $150 shipped to my door. They even tested it (don't know how?) before calling me back and telling me it was good. SO....Hopefully early next week I'll get the compressor and get it installed and filled.....I gotta tell ya, it's been warm without the A/C. (100+ all week) Other than that, all is well. Ordered a used starter too. I think the solenoid is going bad......does the "click, click" thing. |
Re: Just Venting
Re: Re: Just Venting
Later?
Have you already concluded and given up to the fact that days before a big meet something will happen to your car? So when's Snowshoe II and Autofest coming up again? VK Quote:
i had a leak recently and had to get some...
damn o-ring replaced. i love this car but its quirks are beginning to take its toll on me. i have got one more guy i can take it to for the suspension gremlins i am having. if he can not permanently fix whatever is happening i am selling my svx.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Re: Just Venting
There's a sticker under the hood that will tell you what coolant is in the car. I have to drive to the dealer over lunch anyway - I'll look for it...
r-12
My 92 uses r-12 and the retrofit kit won't help me with a bad compressor.
After I have replaced everything and then get the retrofit kit, I'd still be paying more for the retrofit kit then I would to have the system charged with r-12 |
Re: r-12
R-12
The 92's do use R-12,unless someone has already had it converted. If so there should be some kind of sticker placed in the engine compartment to say so.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
