Old 06-04-2003, 02:18 AM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
Stereo wiring question
Gidday all
I'm doing the head unit wireup deal, like all you others, and have sussed out most of the wires in the 20 pin connector that goes into the factory unit. A couple still bother me though, wonder if anyone can help....
1) 14 pink - goes to the "Time Control Unit"and also goes to the clock. Is this the dimmer circuit wire?? I don't seem to be able to reconcile a time control function with any of the radio functions!!
2) 16 Black/white stripe - dunno what this is.
I have the factory CD player with audio controls on the steering wheel. How do the controls tie in with the factory unit? I've got a suspicion that 16 is something to do with this.
Can't find a wiring harness here either (in NZ) that will fit, and I don't really want to start cutting them all!
Cheers all
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 06-04-2003, 02:48 AM
A flight-less flyer
Problem solved!
Thanks to SVXDC for his superb document regarding all these things. http://www.geocities.com/svxdc/Audio...ReceiverWiring
I guess (even thinking wishfully) that there is no way to utilise the steering wheel satellite controls??
Just Crusin'
Old 06-09-2003, 10:57 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
You're quite welcome, Matt!
It's too bad you didn't ask this about 3 weeks ago -- I have some friends who are visiting NZ right now; I could have sent one of my SVX harnesses down with them. (I've been wondering why nobody outside the US has even inquired about them)
As for the satellite buttons on the steering wheel, just a wild guess, but undoubtedly they use that single wire to send a serial pulse stream, like an IR remote control, only wired. So if you really wanted to make it work, you could build a little box with a microprocessor that reads the signals from the steering wheel and then translates and retransmits them as IR to an after-market radio that has an IR remote.
David C.
Old 06-15-2003, 01:50 AM
A flight-less flyer
Hmmmmm...
I think you've just given an Engineer a challenge!! (However, I must admit that my skills will probably not be up to the challenge - I am a Mechanical eng and not an Electrical one!! Bugger...) I was thinking of swapping the steering wheel into my mothers SVX but she has the Airbag and I would say there'll be a lot of different guts in there.
Cheers
Just Crusin'
Old 06-15-2003, 10:23 AM
kuoh kuoh is offline
Or just buy an aftermarket head that has a steering wheel remote. The Pioneer in my SVX works great with it.
KuoH
Old 06-15-2003, 10:44 AM
alacrity024
do y'all think it would be possible to buy a steering wheel from overseas and connect the remote control buttons to a USDM SVX stereo?
-adam
Old 06-15-2003, 05:11 PM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
-adam
No because the JDM steering wheel with audio controls doesn't fit the US models.
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
Old 06-15-2003, 05:24 PM
Green1995SVX
The JDM model with the radio controls does not have an airbag. because of this, it won't fit because the USDM airbag clockspring will be in the way on the steering column.
Mike
Old 06-15-2003, 05:31 PM
SVXdc's Avatar
And to nail the idea shut, I'm fairly sure that the US stereo won't be compatible with the steering wheel buttons, since the radio uses a real pot for the volume control, instead of digital up/down buttons. I'd be very surprised if that pin on the back of the radio (pin 16) is even connected to anything inside the radio.
David C.
