Old 05-27-2003, 12:22 PM
Mr. Pockets's Avatar
Moderator
Dakota digital ATF gauge
A couple of you have installed the Dakota Digital Odyssey series ATF temperature gauge in your cars. I purchased one, but I'm having a hard time installing it. Well, I haven't actually tried to install it yet - I need to find all the parts first.
I don't know how to put the sending unit in the fluid path. I would like to place it in the line that goes out to the cooler, as close to the tranny as possible, but I can't find any fittings that will help me do that. I was hoping that I could thread it into a T, but nothing I've found will work.
Can anybody give me some suggestions?
Thanks.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 05-27-2003, 12:40 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Buy a PermaCool filter to replace the stock unit. The PermaCool has a threaded hole especially for a temp sender. There are a bunch of folks on the site that are running this set up (I've only gotten as far as the filter - still no temp. guage).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-27-2003, 12:47 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
I have a brass T installed in mine, if you want a pic of the setup, email me or get me on IM
ICQ 9615908
Yahoo Zeppelin_hs69
AOL ZeppelinSVX
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 05-27-2003, 12:51 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Putting on the sender
Go to Lowe and look in the plumbing section (in the drawers specifically) They'll have plenty of different T contraptions that will work all for like 35 cents or so.
Old 05-27-2003, 02:34 PM
Moderator
Re: Putting on the sender
That's actually exactly what I did, but I couldn't find anything.
Oh, you know what? I tried Home Depot. I'll take a look at Lowes instead - HD never has what I'm looking for and I always end up at Lowes, anyway.
2005 Outback
END OF LINE
Old 05-27-2003, 02:35 PM
Moderator
-Bill
This sounds like the best solution. I'll put one of these on - I needed to install an external filter, anyway.
2005 Outback
END OF LINE
Old 05-27-2003, 04:11 PM
I have one of the PermaCool filters and it is a nice way to go. I am thinking of doing the same to the 5 speed even though I don't put on a cooler. It would be nice to see what the difference is between the auto and 5 speed temps.
Old 05-27-2003, 04:27 PM
immortal_suby's Avatar
Thread Killah
How will you get a temperature from the 5 speed? Are there any plugged holes in the gearbox to thread a sending unit in or will you drill and tap something. I don't remember any external gear oil lines on the 5 spd box in my wagon but maybe they changed something since then.
Locker Link
2015 BRZ Limited 6MT
Old 05-27-2003, 04:38 PM
I'm not sure yet, but there is a line that comes from back there to the radiator in and out fittings and back to the tranny again. I just thought of that too, now that you mention it. I will get the car back up on the ramp and look to see what is there now.
Old 05-27-2003, 04:54 PM
Moderator
If the 4EAT's problem, in the SVX, is heat buildup due to the clutches. Manual boxes aren't hydraulically driven (typically, wise guys), so I don't know that you'd have any means (or reason) to keep an eye on the fluid temperature.
But whatever floats your boat.
2005 Outback
END OF LINE
Old 05-28-2003, 12:26 AM
Yep - that is a good point. Maybe I should just work on the AC instead. Working that manual works up a sweat!
