Old 05-19-2003, 10:24 AM
gotsubarus gotsubarus is offline
Send a message via Yahoo to gotsubarus
Checking Trans Fluid?
What is the correct way to check the trans fluid when cold? and when it is Hot?
Because of the different marks on the Dipstick......
Also any fluid recomendations as far as Brand?
Old 05-19-2003, 11:21 AM
mattski mattski is offline
Start the car and run through all the gears. Finally set it in Neutral and continue at idle. Check the oil level. I usually let it warm up to operating temperature.
Any Dextron IV should be fine. Or you can switch to Synthetic to take advantage of the improved heat handling abilities. Mobil 1 seems to be compatible with non-synthetics. Drain out what you can which is ~ 6 quarts. Replace with new fluid. Repeat at desired intervals, 5, 10 or 15k miles.
More importantly, get an auxilary cooler if you do not already have one.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 05-19-2003, 11:53 AM
that is the way i have always done it warm....... So how about the cold file lines on the dipstick?
Old 05-20-2003, 02:15 PM
driverdave driverdave is offline
Boring Member
those are just there for the impatient folks that don't have the time to let it warm up.
They are different because of the expansion of the fluid as it becomes warm.
Old 05-20-2003, 02:32 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Trans fill check
FYI it takes my SVX about 20 minutes of driving for the tranny to reach normal op. temp. 140-170 degrees from a 1st start for the day. Its not when the eng temp gauge reaches n.o.t.
