Old 05-15-2003, 09:58 AM
jpsull
A/C o-ring question
I need to replace the o-rings on the a/c connections at the compressor. Should I use any kind of dressing on the rings to make them seal better or last longer?
Thanks,
John Sullivan
'92 SVX
Old 05-15-2003, 03:24 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Use the appropriate refrigerant oil for the system to lubricate the o-rings before assembly.
Old 05-15-2003, 03:51 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Where did you find the O rings? I couldn't find a part number and the local parts stores around here don't sell AC parts anymore.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 05-15-2003, 04:39 PM
Beav's Avatar
Not as old as Randy
Usually you have to buy an assortment. Best and cheapest method would be to take the ones you need to a repair shop and have them match them from their assortment. Toss them enough for a six pack and everyone should be happy.
Old 05-15-2003, 05:32 PM
I'm fairly certain you can't just use any o-rings.
My (yet to be installed) R134 retrofit kit came with all green o-rings (not that the color is what makes the difference). I'm sure there is a difference other than not being able to mix the old ones with the new ones.
Old 05-15-2003, 06:27 PM
Beav's Avatar
Not as old as Randy
The green rings are supposedly slightly thicker to accomodate R-134 which is molecularly smaller and more prone to leakage. We've been using the green, blue and original black o-rings for several years now and there really doesn't seem to be any advantage of one over the other. If I recall correctly the green rings were originally designed for Fords that had an issue with leaks at their slip-connect fittings.
