Towed SVX
A friend of mine is looking at an SVX to buy. It is a 92, and has 77,000 miles on it. The dealer told him about the small things that were wrong - small dings here and there, bad tire, and a couple other things that are easily fixed. He then told me what the dealer told him next which sent shivers up and down my spine!! He said that the previous owner had towed it behind a motor home. He said that he thought that they had put the front end on a dolly and had put the fuse to make it front wheel drive only, and had towed it that way. Doesn't that destroy the tranny? The dealer said that it drives fine, but I really wonder what this might have done to the car, and if it should be avoided at all costs. Please let me know what you think, he is in the process of buying the car, and I told him I would find out about it for him. Any quick reply would be appreciated. Thanks in advance.
Re: Towed SVX
Yes, that is how I remeber it too. when I had to have my 93 towed, the driver of the truck said that the only way someone should ever tow it with wheels on the ground was to disconnect the drive line in the front, and tow it with the back wheels off of the ground. I am sure this RV driver did not do that. What I am confused about is that it has not exploded yet, and it has 77,000 miles. This guy was the original owner as well. I will check the manual and see what it says. Thanks for the information.
Meanwhile, I've heard more than one story about towing companies having to pick up the tab for an SVXers tranny replacement for making just such an error. I can't believe the sucker hasn't grenaded, either.
Randy -
I am kind of comfortable in my chair right now, so maybe you could go out to your car and get YOUR manual and look it up for me. You wouldn't want to disturb me would you? OK, OK I'll get up!
So what's to learn from this?
I just bought a 95 LS... shot tranny of course. I read the manual and about that AWD-FWD switch... what does it do exactly (how does it make the car "FWD"?) Can it be driven (on its own power) with the fuse in FWD mode? Could a switch be made to change the drivetrain mode from the inside? |
Yes, you can drive it in the FWD mode, but not for long distances. I suppose you could install a switch to do that, but I don't know why someone would want to.
The reason why you are not supposed to tow SVX (or any car with automatic transmission for that matter) is the lubrication of the gearbox. Normally transmission is lubricated via an oil pump, the pump is connected to transmission input shaft and only pumps when engine is running. If engine is not running, the pump is not working.
For short towing distances there is residual oil on clutches/gears, but it's not enough for long/fast tows. Installing FWD fuse makes absolutely no difference while the car is being towed without ignition on/engine running. If you lift front wheels of the ground, but not the rear ones, the transfer clutch gets to suffer - there is a lot of motion there and again not much lubrication. Hopefully this can be repaired by replacing just the transfer clutch without removing the whole transmission from the car. |
Ask the guy to put the car on a lift and see if the AWD drive is working. All four wheels should spin and have power to them. Maybe with the front of the car raised up, the fluid level is higher in the transfer clutch section. This would bath the clutches all the time. I think you are dealing with a 'GOOD" dealer since he told you about the RV towing. Se if he would take off a lot of money Also does the odometer rack up miles when the car is being towed? Maybe it has lower miles on the engine then it says? |
Thread Tools | |
Display Modes | |
