i have a 1996 svx that will not idle
i bought a 1996 svx the timing was off so i fixed that and now it wont idle
Re: i have a 1996 svx that will not idle
Not to sound like you are wrong, but are you sure you set the timing correctly? Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
if timing is correct, cracked vacuum lines?? mas info=much helpie
i checked timing again timing was one tooth off on right side fixed that the car now idles but idles rough
heres the hole story on the the car i bought it from a guy in minn, mn for $650 the car has 163000 miles on it the guy told me he had replaced the tranny 20000 miles a go with a tranny that had 30000 miles on it he then told me that he had replaced the the water pump and timing belt and drove the car for a few months when i bought the car it was not running because the timing was off when i checked it it was 4 tooths off on one side now the car runds good but has a rough idle the guy told me the car had sat for a year before i bought it it had a half tank of gas in it could the rough idle be because of old gas |
The guy probably set the timing to where you found it, I bet he tried to use the arrows to set the timing, scratched his head when it wouldnt start, and gave up on it for a year before deciding "Im too lazy to work on it again, lets ditch it and buy that EBay Starfleet uniform we always wanted". So hopefully now its in better hands. You can try Seafoaming it, check the plugs too, its a pain but you cant diag a bad idle without verifying the plugs condition. Hopefully that waterpump job wasnt to try to correct an overheating problem, or 4 out of 5 experts here will agree its your headgaskets |
Install the timing belt correctly first...
Keith |
