i have a 96 ecu, but its a diffrent type of hesitation, sounds like im running on 2 cyl's, its really embarrising.....
Is it the strange hesitation around 3k RPMs? My car had that too. You'd floor it, the car would rev up... then hit 3k and pause... then continue revving. Shift and repeat.
I fixed this problem by installing the ECUtune Stage 1v5 chip. |
nope its not actullay a hesitation but a series of backfiring and bogging.... u floor it and it just completly goes wack.... even mild or easy accel. and itll do it
Maby you should make sure you have the correct ecu for your year.
IT'S 5:00 SOMEWHERE!!! 92 Liquid Silver SVX LS-L |
no its correct, it had same symptoms before the new ecu and i had the new ecu baught and installed by a performance subaru shop, it was a brand new ecu btw
would try replacing the MAF sensor, and the TPS. I had a problem with hesitation at specific rpms. I cleaned the MAF and it made the problem better, but didn't completely fix it. Installed a new MAF and everything was golden.
not the maf or tps either, i put a good maf on, not the problem, cleaned and adjusted the tps to .5v, also not the problem.... though my fuel pump makes a nasty squeal on start up....
well that could very well be your problem. If your pump is bad, it will cause erratic behavior. Do you have access to a fuel pressure guage? If the engine is not running properly, it could also cause shifting issues.
i was told by a member here that if im having hesitation that dont change my fuel pump... i had a good fuel pump and everything ready to go till i heard this and bagged the idea, , u got it right, it does shift very weird into 2nd, takes a good 4 seconds at easy throttle to actullay go into gear
I wonder if Subaru just took out the bulb in the OBDII cars. I wonder if it would illuminate the way it used to if a bulb were installed? I can't see a redesign of the instrumemtation circuit just to eliminate one bulb. Sorry for the confusion on my part in the initial post. .
Thread Tools | |
Display Modes | |
