Old 05-24-2007, 05:25 PM
UPnorth362's Avatar
UPnorth362 UPnorth362 is offline
Send a message via Yahoo to UPnorth362
Ok... So I had a problem just last weekend that sounds very similar. No CEL, and it would just stall at speed during quick altitude changes. It started doing it after I used the CRC MAF cleaner. Put the MAF on another car, with the same results. So last night I soaked the MAF in vinegar, and re soldered all the contacts and resisters. Put it back in this morning, and drove 200miles. The car ran smooth, no hesitation, no stalling, and the MAF voltage seems to stay in spec. Maby you can give it a shot.
IT'S 5:00 SOMEWHERE!!!
92 Liquid Silver SVX LS-L
Old 05-24-2007, 05:28 PM
I cleaned and then replaced Brian's MAF in hopes of it fixing it... I did not claim the MAF to be bad because I had one to sell him... Only because I figured the same thing... But this problem was also encountered in another person's car... all the symptoms point to the MAF but it just isn't the problem
Old 05-24-2007, 05:58 PM
UPnorth362's Avatar
What is the chance of an O2 sensor going stray, causing the O2 average to go hi and making the car go lean? I think as long as the O2 sensor registers a value, no CEL will be displayed. Have you used a wide band, or select monitor to measure the O2 levels when the stalling happens?
Old 05-24-2007, 09:41 PM
Thats not how 02 sensors work... They throw a CEL when the readings are nill or out of spec. Besides that... It is not consistant which leads me to believe it is an electrical fualt
Old 05-24-2007, 09:47 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Brian, Where are you and your car? I could take a look at it if it's close to me and try my MAF on it if that is the suspected problem.
Old 05-24-2007, 09:50 PM
That isn't the suspected problem... It is the same issue Dan94SVX is having... suspect at this point is the ignition switch dropping its current for brief periods of time... The switch I offered to ship to Brian for free
Old 05-24-2007, 09:59 PM
Budfreak's Avatar
Banned
Aahh, OK. I got lost in the conversation there somewhere.
Old 05-25-2007, 11:55 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Brian... your car is doing the exact same thing Dan's is... Diagnosis has led only to the ignition switch... I had gotten one for him but he already has one... Do u want me to ship it to u?
yeah why not, I'll pm you my address again just in case you don't have it.
Brian
