Door lock problem....
Hi everyone,
Has anyone experienced problems unlocking the driver's side door with the key....? Often when I go to unlock the door, the key is quite difficult to turn and when I release the key, the doors re-lock! Sometimes, I can barely turn the key to the unlock position at all. The next time I unlock the doors, everything is back to normal!! Any ideas? Thanks
1994 Dark Teal SVX With real HID & Small Car Shift Kit (310000 km and counting) |
first off lube it
then check out the problem I had at http://www.subaru-svx.net/forum/show...&threadid=4269
same problem!
hello joe90!
I have the same problems some time. But one day to another it works again. I don't know why. If the door is closed first you have to turn the key into the closed direction, then to open (this one should work, but not help to solve the problem) mfg hrc
Ænima |
Hi Marty...
Yesterday, I took the lock apart only to find that a pivot inside the lock was worn.... To make a short story, I had to improvise and fabricate a new pivot using a solid rivet. It seems to work now. Time will tell Joe 90
Problem?
Hey Joe (isn't that a Hendrix song)
Nice to hear it works again. My problem hasn't occured for a long time now. I hope it goes that way on. mfg hrc
Ænima |
