Old 04-21-2002, 12:03 AM
jbarber
Paint type used on '92 SVX's?
It occurs to me to wonder if Subaru used acrylic lacquer, or acrylic enamel on the '92 SVX.
The reason I ask is to determine whether cheap (lacquer) touch-up paint will blend with the factory paint. (I haven't seen enamel-based touch-up paint in the parts stores, unfortunately..)
Thanks,
--jim
Old 04-22-2002, 01:45 PM
Mr. Pockets's Avatar
Moderator
Re: Paint type used on '92 SVX's?
Thanks,
--jim
Don't even wonder about it. Just go to the dealer and get the touch up paint from them. It'll be less than ten bucks and match up perfectly.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-22-2002, 01:57 PM
Green1995SVX
Also, www.paintscratch.com I ordered some paint from there. Perfect match.
-Mike
Old 04-22-2002, 02:16 PM
jbarber
Re: Re: Paint type used on '92 SVX's?
Yes.. I didn't mention that I'm wanting to repair and blend some door dings. Takes spray paint. It can be done quite nicely -if- the paint chemistry is compatible with the original.
--jim
Old 04-22-2002, 02:23 PM
Green1995SVX
I highly recommend the use of the base/clear process available at www.paintscratch.com if that is the case. My stuff came out great.
-Mike
Old 04-22-2002, 06:19 PM
jbarber
Thanks, Mike. I'll check 'em out.
--jim
Old 04-22-2002, 07:41 PM
wawazat??'s Avatar
Yeah, I'm still around
Send a message to
double0bondo. He owns a bodyshop and should be able to help. I also think Doug (mohrds) can help with your paint questions.
Todd
Down to none
