Old 07-18-2005, 09:29 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
Installation of engine mount(pass side)
Hey, all I got the pass side engine mount in, but I couldnt get the rear bolt in. I took it out by going through the mount(the mount was split in half). But I cant reach the rear bolt. Does anyone have a DETAILED set of instructions on how to install it. Thanks
Old 07-19-2005, 04:33 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Remove the torque strut and the exhaust at the manifolds to jack the engine up high enough. Disconnect the O2 sensors so you don't pull the wires in half. Remove the sway bar and use a flex socket. Or just leave it off...
