Old 07-06-2005, 10:53 PM
oh man... didn't want to have to swap the carrier
Oh well
Old 07-07-2005, 05:30 AM
svx_commuter's Avatar
Originally Posted by TE1221
I think the only other thing you need are the seals, screen filter, and pan gasket, as well as gear oil for the rear diff
I think this is a great way to go instead of getting a rebuilt tranny from Subaru or anyone else. I can't use a manual tranny in my commuting. There are some days when my left leg would just die.
So I am just checking again. Does the drive shaft or tranny mount have to change? Any extra pieces to add in?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-07-2005, 06:14 AM
lee lee is offline
No. Only change is to swap the rear gears and carrier, and the speedo sensor - the tranny is a pure bolt up (assuming you use the SVX torque converter).
Old 07-07-2005, 06:20 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Currently my rear transfer clutch is gone so I only have FWD but the trans shifts fine.
You think I should get the TC rebuilt/flushed?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-08-2005, 04:34 AM
What's involved with changing the torque converter? Dosen't the transmission have to come apart to swap over the TC?
Old 07-08-2005, 11:13 AM
lee lee is offline
Tim,
If you have the ready cash I would get it checked/flushed/rebuilt for piece of mind. With less cash available, I'd drive it a few miles then re-drain & change the filter again - why, because if a clutch has failed, that clutch material has to be somewhere - probably not much in the TC, but since the swap is such a pain, a few more minutes and another filter is chump change (IMHO).
svx_commuter, the transaxle has to be pulled, but not separated. The TC sits between the engine and the differential. There is a hollow tube (I forget its real name) that passes through the differential, and which couples the TC to the tranny input shaft.
Old 07-12-2005, 11:02 AM
Tim,
Are you saying that the Impreza TC just slides out off the tranny shaft and the SVX TC just slides right on? I assume there are some splines or something to line up. No o-rings or seal to change or damage?
Old 07-12-2005, 12:44 PM
change the front seal on the trans when u do the swap. yes they just slide out and the new one just slides on. All of the 4eat in that version have the same spline and input shafts
Old 07-13-2005, 09:43 AM
Originally Posted by Chiketkd
Yes, it will work - the gear ratios are 4.11.
You'll need a rear diff from a 4.11 Legacy though - the ones from the Impreza are tiny and won't match up to our axles or accomodate the limited-slip hub.
-Chike
91 Legacy is okay?
