Old 01-23-2005, 06:22 PM
Speedklix's Avatar
Locker Link Solution
woah?? just a year ago? I really thought it was back more than that!!
I considered the single wiper mod, but decided for function over form. If you do it my way...
You can do it by just cutting the linkage and use the passanger side arm. You have to weld in some CRS to lengthen the linkage (or use some from the other side). I can't remember what the exact length you need to add is, but you can change the sweep area that way. I think I used a shorter blade to do it.
In the pic it looks like he may have just repositioned the arm though.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
