My two most challenging issues...
Two more issues that I'm plagued with:
1) The front CV boots are both torn. Should I replace just the boot or the entire axle? The independent shop I take the car to indicates that replacing the boot itself is nearly the same price as rehabing the entire axle. Thoughts? 2) Nobody in the Southern California area seems to know how to align the front wheels. What are the specific settings that work best. The insides of the front tires were wearing, now the outsides are almost bald after having the alignment redone. I know this car historically wears tires in a strange way due to the AWD. |
If it was my car, I'd just replace the axle. When the boots tear, they let dirst and water into the joint and that just turns the grease (what doesn't fling out) into an abrasive grinding paste.
It's unlikely you caught the tear quickly enough to prevent this from happening, so the damage is pretty much done. Just getthe axles replaced. I actually did catch a rear axle boot very quickly, and I did just replace the boot. It's been fine since I did that in early 2000.
tire wear
I've personally owned 15 Subarus, ( that I can remember) 1 front wheel drive, and the rest awd or 4wd. This not counting parts cars or the ones just bought to resell, and I've only had to align two cars! One because my then-wife hit a curb, and my 92 maroon svx, first due to inner tie rod end replacement, and again to a bad alignment. Evan tire wear has allways been a Subaru strong point! Please have someone who can give you a before and after printout, and go with the factory specs. Tom
ps; go with the new/rebuilt axles, it's money well spent. |
Re: My two most challenging issues...
As far as the alignment goes, look elsewhere, there are many shops with good 4 wheel alignment racks, and if you can't find one is SoCal, I would be very surprised. 2) your problem is not alignment, its tire Under-inflation. I just went thru the exact same issue. My shop checked the alignment, and the machine also tells them I need 39lbs in the fronts and 36lbs in the rear on my stock wheels and tires. The ride gets a little stiffer but it will make your tires last, and wear properly. I think there may be a thread about tire pressure, I will look, and if not, will post one.
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
Do you have the details on the factory specs for the alignment?
alignment specs
primary angles caster l+r 4.1dg min to 5.6dg max
front camberl+r -1.2dg min to 0.3dg max toe -0.10dg min to 0.10dg max rear camberl+r -1.4dg min to 0.1dg max toe -0.10dg min to 0.10dg max thrust angle --- secondary angles sia l+r 16.0dg included angle 20.0dg |
Re: alignment specs
Please tell me how you adjust "Rear camber" if there are no camber bolts in the rear ............... You can get rear camber bolts but they are not stock... I am running -1.5deg in the front and about -1.0 in the rear because of the Koni/GC setup... Nope, I don't have camber bolts in the rear... The suspension sits so low though that the wheels sit at about -1.0 degrees and as ya corner they hold VERY nicely because the contact patch in the rear holds pretty evenly...Ya know, the more ya press the suspension down the more "camber" you're gonna get... Anyway... Just my input... If ya have a stock suspension though, have a Subaru dealer do the alignment... They should have all the specs onfile for ya there... If they dont then they are teh Suck!!!...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
alignment spex
Green Marine, Hey sailor, It's 9:06, I'm on my 4th margarita, I left the alignment specs on my desk at work. Maybe I misspoke, (actually now that expression sounds kind of dirty) this photo might clear things up.
OK,OK it's now 9:34 the fifth margereta iss now long gon and its sleepytim now |
