Headlight help!!!!!
I am trying to get the headlight assembly out to clean it. I can't seem to get it detached at the corner. I see what I think is holding it in but no idea how to release it. I am stuck until someone tells me. Did search no help there.
On the respective far-side of the headlight assemblies is a single screw. This screw runs through a small bracket that is actually attached to the turn signal assembly. Remove the screw, and pull out the turn signal assembly. If you're standing in front of the car, you pull the assembly toward you. It may be a little difficult at first, but it will pop out.
After that, I believe there are just a few screws holding the headlight assembly in place. Remove them, and pull out the assembly. I can't fully remember, but when I did this, I had to remove the center mock light. I'm not sure if I did it to remove a "hidden" screw, or just because I myself wasn't sure on how to take the assembly out. Good luck. |
