The dreaded drooping sunvisor!!!!!!
OK so can anyone let me know how to fix a passenger side drooping sunvisor? It is driving me crazy. I do not want to damage the fabric, so therefore do not want to use double sided velcro etc. What are the cures for this annoying problem? AAAARRRGGGHHH
I wedged the plastic halves of a Cialis capsule onto the visor rollers. The visor stayed up for 4 hrs. than died toally
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
double sided velcro
my red car's previous owner has put a piece of of this tape from the visor to the hoodliner, its about 3 in long and 1/2 in wide...does the job but looks ugly...most people who get in say hey whats this ..then oops ..sorry...as it just misses them
I asked my wife the other day when she was in the car as she's very handy with craft stuff, about putting a velcro patch or two between the visor and the roof, so as you push the visor up it sticks..will let you know when we experiment D2 Oz
Dave Down Under |
Asking to not damage the fabric probably means the only real solution is a new (or slightly used) visor. Not that it would work for everyone, but I slit mine along the seam, went inside and gently squeezed the round metal part that rubs against the flat on the arm, then sewed the visor back closed. |
Velcro - no
Tried Velcro, it pulled down the headliner. I fashioned a little clip/wedge out of a section of wire coat hanger which I have stuffed into the door trim and 'swivel' it backwards and forwards to catch the corner of the visor.
Not real pretty, but functional.
Diana 1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint |
I believe only Subaru have the problem that extends this far.
In most models of cars you can tighten the hinge of the sunvisor, but I think you'll find that if you don't want to put any patches or the like on your car, you'll probably have to buy a new sunvisor. I had the same problem with a 91 subaru liberty, and they had the same or very similar mechanism. Paulie. |
peeved
One would think that for the not so small initial outlay for an SVX, that this little problem would have been ironed out? I find it difficult to believe that Subaru do not know of this problem and have not worked out a workable solution without their customers going to the expense of a completely new visor, which will probably suffer the same fate.
Isn't it funny how those seemingly insignificant things tend to bug us the most? Like the fading red plastic bits that we can't seem to buff up or out (huh David!). Oh well- I might try slipping and gluing a small magnet inside the headliner and do the same for the visor- in an inconspicuous spot of course. Mark. |
Re: peeved
Kenn |
Thanks for the tip, hadn't thought of that. D'OH!!!! yet again.
Peeved [cont]
absolutely right about stupid thigs that could/should have been ironed out...
sunvisor ...just dum surely from 91 intro by 93/4 someone in Japan or anywhere must have started noticing the auto sun block visors... OR windows ...the self scratching 'auto' windows..design a better window guide/or window rubber for Bjesus sakes...but also make sure the glass is damned expensive to replace should the hapless owner try to outsmart the dirty guides...on a +ve note though I got Subaru to clean all my window guides ..then had the windows buffed $80 aside ..Subaru - workshop charge $50..and so far so good..the window guy explained that scratching windows is a common problem [ta !!] and that when washing ease window rubber back wash the inside contact area with soapy sponge and then flush liberally with water [hose] [again holding the rubber back..kind of slide youtr finger along [don't blast it..goodnees knows where that water will go]..but certainly flush..when I washed mine for the first time I couldn't get over the dirty water that flushed up along the glass...doing this should ensure the guides don't collect the crap off your window when dry and accumulate then start scratching...so far so good ...scratches can't be totally buffed, but when clean and dry it looks pretty good...deep scratches may not buff out..so you'll see those 'glinting' in the light .. Hungry CD player ? - yes when its hot..doesn't take much ..won't let you eject the CD..when its cool no problem..something to do with newer materials used for CDs [thinner/thicker - originals or burned - 2 cars same years 95s same problem] ..a bit like some of the newer credit cards ..the thickness of the plastic changed..which caused some EFtpos machines not to be able to read them [eg. in Oz 2003+ issued CBA cards]..now that I figured that out just work around it.. Auto dimming headlights - yes progressively go foggy overtime, I know a guy in BrisVegas has offered a service of changing out the headlights [SVXs] for like new .." that'll pass insurance/rego inspection" for $150 a piece..pricey but its done and should be good for a couple of years...I'll look at this down the track when I need it. OK I'll stop grumbling D2Oz |
Re: Peeved [cont]
HA! Sounds like a legitimate "feature"!! <hoping that my sun visors will continue to stay up.......! > Jason.
1992 Charcoal Grey SVX - 165,000km 1992 Ruby Red SVX - 165,000km ....now with sequential VIN numbers! 1986 Holden (Isuzu) Piazza Turbo - 225,000km 1993 Mercedes W140 S500 Coupe - 153,000km 1990 Mercedes W124 300D - 313,000km EG33 + 4EAT + VTD AWD = SVX |
Re: peeved
However when I bought my JDM spare replacement visors about 2 years ago, Subaru only had a few left and were NOT going to have anymore made!
paddlesnz 1993 Subaru Alcyone SVX 1980 Isuzu 117 Coupe Giugiaro Edition 1999 Mazda Astina 2006 Honda Legend 2006 Toyota Mark X Premium 2007 Toyota bB 2007 Mazda Roadster RS 2012 Peugeot 208 Allure |
Hey David, the foggy headlights, the hungry CD player, the scratched windows, the droopy sunvisor....are you sure you and I don't share the same car? And you say you own a red '95? There is something spooky going on here (start the twilight zone music).
Mark. |
Southern Drooping Visors
Haven't noticed this problem on Queensland cars though.
Must be that with all the "Sunshine" up here that we just leave them down all the time. Unlike Southern States were you have them up and down about 10 times a day Kenn |
Thread Tools | |
Display Modes | Rate This Thread |
