Old 04-23-2007, 03:07 PM
braaap11889 braaap11889 is offline
Power windows/sunroof don't work I USED SEARCH
All of a sudden my power windows and sunroof stop working. NONE of the windows work. None of the switches work either. The drivers seat does have power though so I don't think its the relay. And I have checked and replaced any blow fuses and still nothing. It was 85 degrees today and I have a black SVX and its killing me to not have the windows down or sunroof open when I am parked.
I also pulled the door panel and the white plug that plugs into the bottom of the 4 switches on the drivers door is in there firmly no blown fuses the relay is fine. The auto isnt illuminated on the switches and the lock windows switch isn't pressed in.
Everything else works fine but why do the windows and sun roof not work.
This is on a 1992 LS-L SVX.
Old 04-23-2007, 10:02 PM
you checked both fuse boxes right? The one under the hood and the one above the driver's kick panel?
Old 04-24-2007, 01:41 PM
Yep checked them both no blown fuses under the hood 1 under the dash for the rear wiper. Its wierd one day it worked then I didn't use it for a day or two then it didn't work. I don't know which one it would be under the hood since the manual doesn't say ANYTHING for windows but I was told its a 30 amp near the middle and neither of those were blown.
SOMEONE HELP I'M DIEING HERE ITS 80 DEGREES OUT AND MY CAR IS LIKE 120 every time i get in there.
Old 04-24-2007, 06:28 PM
Fixed was some wires in the under dash fuse area. Something must have been messed up under there just shook some wires and windows work. The cars like new now can't wait to pick up babes like I did last summer. These cars a chick magnets.
