Old 05-10-2007, 09:41 AM
anthonybuchanan anthonybuchanan is offline
Best offset for 18" wheels
Hi everyone, I'm determined to remove my stock wheels (and save them in the event I need them later) and replace them with 18 inchers.
My question is do all wheels have a different "SVX" offsets ?
or,
Is there is a standard "SVX" offset ?
Old 05-10-2007, 10:06 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
In my opinion the proper offset for a 18" rim on the SVX is about 10 feet...
Factory offset is 55 mm, there's a good tire size/offset calculator in LarryIII locker.
Old 05-10-2007, 10:29 AM
The offset needed doesn't depend on rim diameter, but on rim width. A 7.5 inch wide rim is going to need a different offset from a 9 inch wide rim.
Old 05-11-2007, 08:05 AM
If you go past the factory offeset of 55 does that result in scraping against the body ?
Old 05-11-2007, 08:17 AM
Hocrest's Avatar
Did you read the other replies?
edit: I just went in to double check, it's in the "speedo error" folder
Old 05-11-2007, 09:06 AM
If you have a 7.5" wide rim and you go past the factory offset of +55 it will move your wheel inward and it will grind against the suspension. If you have an offset of less than +55 it will hit the body. You have a bit of room for movement, but not much.
