Old 04-25-2001, 02:50 PM
KEVINL
The A/C in my SVX blows out the defroster vents and floor vents. I can't get it to blow out the normal vents. Does any one know whats wrong?
Old 04-25-2001, 03:27 PM
eddycat2000's Avatar
eddycat2000 eddycat2000 is offline
Dumba$$ Mechanic
Ummm...is that a question or a statement? If it's a question, sounds like mode motor time to me, if it's a statement, sorry dood.
Old 04-26-2001, 05:22 AM
Joe 90's Avatar
Joe 90 Joe 90 is offline
Canadian eh!
Hi kevin,
Well, mine also does that from time to time.... What I do is to change the TEMP setting from COLD to HOT a few times... this sends a signal to the motors actuating the flaps in the heater box.... If that doesn't work, I simply reach under the dash and just "manually help" the motor move the flap....
Look under the dashboard (driver's side) while changing TEMP setting from full HOT to full COLD a few times, you'll see the motor actuate the flap (if the motor is not simply dead). That way, you'll see which one I "manually help"...
This only happens very rarely in my case, that's why I never got around trying to fix it but I think some lubrication would cure the "binding" problem....
Hope this helps
Joe 90
