Old 04-11-2018, 08:11 AM
Wow what a car !!!!
Been sitting on a trickle charger since October. I have a date on Thurs . Said I may take the car. .took off the cover. Opened the door. Stepped on the clutch turn the key and it was running. I did just barley hear the starter.
Old 04-11-2018, 10:30 AM
Re: Wow what a car !!!!
It was die'ing to get out of the garage and into the sun!
Old 04-11-2018, 11:06 AM
I had the same experience. Car was parked in a cold garage since November.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 04-15-2018, 06:58 AM
theflystyle's Avatar
For those of you who keep the car in the garage all winter, do you perform any special pre-start procedures before first crank? For example, manually turning over the engine to lube up the internals. After a months of sitting, all the oil must be at the bottom of the engine and the idea of that first start just makes me cringe.
I also keep my car in the garage all winter and make an effort to start it and let it idle in the driveway on decent days to try to keep those 'dry-starts' to a minimum.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-15-2018, 09:57 AM
The plan was to have it crank. Unfortunately it did not I shut it down after a few seconds and let it rest. Restarted. Oil pressure came up instantly. Fig all thirs new cars in the dealer lots. Sit months with 4 miles on them. They don't prep them. At the Subaru factory. It comes off the production line onto a dyno and revd to 5,000 RPM. I saw it with my own eyes.
Old 04-15-2018, 02:19 PM
Whenever my SVX has been sitting for a while, 6-9 months, I just disconnect the igniter back on the firewall and crank it for about 20 seconds to manually move the oil without starting ( the oil light actually goes out) Then plug it back in and it fires right up.
Stays connected to the Battery Tender when not driven.
Old 04-17-2018, 07:31 PM
Tmazzola12 Tmazzola12 is offline
Where is the igniter you speak of located SVX Mage
Filled my motor with 6quarts of oil/ 2 quarts if mystery oil
Last time I changed the filter and ran it about half hour total about 4 months ago have not started it yet and would to mush it around before I start it
