Old 04-06-2018, 10:49 AM
It may happen this year
Did my taxes. And I may just do it and spring for the rest of the paint and coil overs and replace all my vac hoses under the intake. Then it will be compleat.
Old 04-06-2018, 12:02 PM
SVX_MY_BABY's Avatar
Re: It may happen this year
Then it will be complete.
That would be a fabulous reward.
Peter
Old 04-06-2018, 08:55 PM
Tell me more about the springs you have. Not sure where to get parts to replace my struts. The ones I have may even be okay. Not sure if the PO ever changed them. He changed everything else. I probably have the most un-original SVX . I will get them checked first.
Old 04-07-2018, 08:01 AM
Mychailo was a member here who designed a few variations of springs which were standard height, as well as lowering ones with a few different options for stiffness. He also fabricated Koni inserts and If I remember correctly a few other suspension bits.
Unfortunately, he no longer does these items. I think I have the spring rate documented somewhere in a file. Any spring shop should be able to make them. If you are seriously looking at a custom fabrication let me know and I'll see if I can find the info. Mine are not made for track use but offer a nice firm ride. Similar to a mini cooper or WRX.
He did have a page / thread on this site somewhere where he posted all the various options.
Peter
Old 04-07-2018, 12:57 PM
92 SVX 92 SVX is offline
I would seriously consider the Gecko coilovers or the TSP, same coilovers but different vendor. The street versions have great spring rates for the car and the ride height can be adjusted with almost stock high as an option. I think at most 1/4” below stock ride height is doable, if your one of those that don't care for the look of lowered cars.
Here are the TSP coilovers: https://www.truspeed-performance.com...1&product_id=1
Actually here is a link to both products on one page. http://www.svxnation.com/products-1.html
Old 04-08-2018, 06:50 AM
This thread has some of the spring info.
http://www.subaru-svx.net/forum/show...light=mychailo
Just search his user name for more.
Peter
Old 05-01-2018, 03:17 PM
bumpsteer's Avatar
bumpsteer bumpsteer is offline
Recovering EG33 Swap Artist
I'm ordering some of the TSP's from SVXNation as my stock struts are blown and Koni inserts cost more or less the same while not including height adjustment and requiring me to cut up my stock struts.
I'm specifying a 5kg/mm front and 3.75kg/mm rear spring rate for a firm yet forgiving ride (~1.25x stock rates from what I understand).
The TSP's and Gecko's seem to be the same coilover but I cannot stand the color scheme of the Gecko's. According to SVX Nation, the TSP's can be raised up to 0.5" above factory height. While they are not designed for this, I'm going to look into how this will affect parameters such as droop travel (i.e. is the spring adjusted or are they BC-style) but I'm interested in being able to lift it slightly for snow and oversized tires.
I'll be installing them on the car at the beginning of June. I'll let you know what I think of them at those rates if you haven't done it by then.
-1996 Brilliant Red LSi *slow*
-2007 Mustang V6 *slow*
-2002 Audi Allroad 2.7t 6spd *slow*
Ask me about a certain midengine Honda Insight
Old 05-01-2018, 08:29 PM
The coil overs have a threaded shock/strut body which adjusts in relation to the hub mount, they also have a preload spring adjust threading but that isn't meant to adjust height just how much cushion the spring has.
Old 05-02-2018, 01:32 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
You can buy Bilstein coilovers or OEM housings with Bilstein inserts at K-Staff.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 05-02-2018, 04:41 AM
Tell me more. This is the first I've heard of this option.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 05-02-2018, 07:55 AM
bumpsteer's Avatar
Good to know, that way I'll maintain droop travel at a lifted height.
Old 05-02-2018, 08:40 AM
jetboy's Avatar
They may be transiting to selling internationally. They sell OEM struts with Bilstein inserts (for us who need to hide mods from authorities) and full blown coilovers adapted by a japanese Bilstein certified fabricator and dealer.
No word as for pricing and process yet but if you wait a little.
Edit: The set in the attachment is a further modified version of the Bilstein coilovers and belongs to a japanese driver.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
