Old 04-04-2018, 08:44 PM
tigersvx's Avatar
tigersvx tigersvx is offline
1992 SVX WHITEPEARL
Inhibitor switch
Hi everyone:
I have owned my 1992 SVX with 110,000km, since August, 2001. Over 16.5 years of ownership. It hadbeen used regularly for only the first 4 years. 5000km each yr. The last 12.5 years only put on 8000km.
Now its 138,000km. Parked most time, used 4000km each time twice during second 4 years.
The last 8 years parked most, from now back was parked 1, 3, 1, 1.5, 1.5 years respectively, Each time only driven 3-40km in 2-3 days and parked. Each time it could started in one click. Only the last 2-3 times I have had to start in Neutral.
The problem of my inhibitor switch was strange this time, after I parked for 1 year, and 3 years before that. Before it could always started in Neutral, but this time, (and last time that I after I parked for 3 years) after I (first time) started in Neutral and run for 10km, shut it off and start again in Park. OK the first time; second time, its silent in Park. So I put it into Neutral... silent too. I put it back to Park, and it starts in one click. Is this the inhibitor switch problem?
Someone said if I use the car frequently, it will come back good, but because I parked it for too long, it forgets its gear position. Any comment?
Please, if anyone can show me the link for location of this switch, and how to clean or change it (I suspect it may just be dirty) and /or where can I get a replacement part. JDM model.
Thanks
1992 SVX whitepearl 129,000km
2005 MAZDA3 red 38,000km
2001 HYUNDAI XG V6.3000
2003 TOYOTA PREVIA
Old 04-05-2018, 05:11 AM
Re: Inhibitor switch
It needs to be driven. Sitting idle is the worst thing for a car. Is it stored indoors?
P.S. Change the oil right away!
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 04-06-2018, 06:26 AM
tigersvx's Avatar
1992 SVX WHITEPEARL
The last 1 and 3 yrs parked it was stored indoors, while previous 1.5 and 1.5 yrs. it was parked outdoors.
But was very clean now,,
P.S. After not changing the oil for 7 yrs, I had changed it about 1 year ago
After parked for 1 year, I now try to run it every 2-3 days,about 10km each.
I will try for this whole April month to see if the inhibitor problem will cease.
It seems that same things happened to my 1999 Audi A6 4.2 with 123,000km
Parked similarly, it got a gear sensor issue as well, whereas when put in reverse, light comes up and car goes limp. I have to restart and go only forward. But after regular use for the past year, the problem is now solved, even put in reverse, no problem.
Hopefully, it’s the same as the SVX
2003 TOYOTA PREVIA
Old 04-07-2018, 05:53 PM
reverse is a manually selected gear ,you could change the fluid and let it warm up
Old 04-07-2018, 06:06 PM
tigersvx's Avatar
1992 SVX WHITEPEARL
Originally Posted by trophy956 View Post
reverse is a manually-selected gear. You could change the fluid and let it warm up
I just found an inhibitor switch on ebay for 82NZD, including postage.
Part no. 31918AA090
It’s for Subaru WRX, 2008 and up.
Anyone know if this part no. can be used in SVX?
(I asked the Subaru dealer in NZ once years ago) They quoted me 300NZD from Japan.
Recon if its only 82NZD. might as well replaced DIY) solved
2003 TOYOTA PREVIA
Old 04-07-2018, 08:01 PM
Tigersvx, you have a private message
