Old 05-22-2012, 06:32 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Antenna signal is bad
Is there anything to boost the signal for my radio reception? The antenna works but I get lousy reception! I lose lots of channels will driving around.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 05-22-2012, 11:32 AM
kjoyes kjoyes is offline
Re: Antenna signal is bad
do you have a aftermarket radio or factory?
Old 05-22-2012, 12:23 PM
kwren's Avatar
kwren kwren is offline
Is this something that happened suddenly or a gradual worsening condition?
Keith
Old 05-22-2012, 02:14 PM
dannmarr's Avatar
I work for my SVX
I have a Panasonic stereo. I get about 4 clear channels. I thought it was normal all these years being that I live in the Poconos. It wasn't until I started using other vehicles to go to work, that I was able to get better reception. The antenna is factory and it does go up but the signal drops alot and with much static on the dead channels. I know the previous owner did swap out the antenna once before. Maybe a bad connection?
Subaru SVX for fun
Old 05-22-2012, 02:25 PM
It's possible the aftermarket stereo is hooked up to the defroster antenna and not to the mast antenna.
Old 10-17-2012, 02:00 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
That, or you may need to clean the motorized antenna's mast. See this post.
David C.
Old 10-17-2012, 05:38 AM
Huskymaniac's Avatar
Uses the ignore feature
What are the specifications of your receiver? The oem panasonic is horrendously bad. I just shopped around for reasonably priced stereos and Pioneer's supertuner 3D is the best. Alpine and some Kenwood/JVC recievers are almost as good. But you have to be careful and check the specs because, model to model, the reception can vary wildly.
Tony
Old 10-17-2012, 05:45 AM
Dave,
How do you get that clip closest to the dash, on the piece on the side of the hump, back in? It is a bear!
Tony
Old 06-11-2013, 02:35 PM
dannmarr's Avatar
I work for my SVX
Your words came into my mind as I pulled out the radio. I noticed another antenna wire (unpluged). The original SVX radio has two antenna wires, while my after market radio only uses 1 antenna wire.
Subaru SVX for fun
Old 06-11-2013, 08:26 PM
dannmarr's Avatar
I work for my SVX
I'm going to reinstall the original SVX radio with the 2 antenna wires. Maybe this will help my bad reception.
Subaru SVX for fun
Old 06-11-2013, 11:24 PM
also, here is what solved my problem Check the 18 inch extenstion cable if you have a aftermarket radio my was bad, one of the end was came seperated from the end of the cable. from pulling on it too hard when installing, i had absolutely no reception. In other words check the cables First!
