Old 04-16-2013, 08:42 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Suspension overhaul: what to replace
So I'm ordering a set of Ceika coilovers as soon as they get back to me. What else should I change on the suspension while I have it apart? I installed new front end links today (much less clunk over bumps). I was thinking front sway bar bushings, rear sway bar bushings, and the $15/15 minute mod. My ball joints are good, already checked them. Axels definitely need to be changed. Anything else easy that I could do relatively cheap and easily? Also, where is the best place to buy the bushings from the sway bar? I'm looking for a stiffer ride, so I'd be happy with the polyurethane ones.
Thanks!
P.S., is there anyone going to Reading that would be able to make sure my brake band is correctly adjusted? I'd want someone who's done it multiple times. I'm not brave enough to do it myself
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-16-2013, 10:16 PM
92 SVX 92 SVX is offline
Re: Suspension overhaul: what to replace
Thanks!
How are the rear trailing arm bushings, or control arm bushings. May not be as easy to change, control arms might be better to just replace entirely.
Front sway bar bushings I bought from summit, the rear I got with one of nevins bars, those are well worth the price by the way.
Old 04-16-2013, 11:49 PM
B 4 You's Avatar
#lolsvx
They're okay (for now at least). Did the ones from Summit require any fabrication? I'd rather just buy ones that slide in as they should. I'm afraid I'd mess it up. Dayle's rear ones just go right in without modification right?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-17-2013, 05:38 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
while you are at it, check your calipers, brakes, lines and rotors. I did mine about 2 years ago but I had to replace them again(not all of them). Damn PA winters!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-17-2013, 06:50 AM
The summit ones I got did require modification.
I however think these days they have sets for all bar sizes, I do not remember the size of the bar but find that and do a search on autozone, advanced or O'reilly part.
you should be able to get the bushings easy enough.
Old 04-17-2013, 08:00 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Check the brake hard lines. Mine were so rotted they became brittle and were breakable by the touch of the hand.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 04-17-2013, 09:15 AM
B 4 You's Avatar
#lolsvx
I just had my rear brake lines replaced because they had rotted away The front ones are still pretty fine, actually. Will check the brakes, just replaced pads and rotors about a year ago so they should be fine.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
