Old 11-16-2016, 09:25 AM
subaru subaru is offline
strange abs light
HiGuys
my abslight is bright and shining in my dash but I get no codes under seat
Changed both relais and checked the fuses in both boxes
Light stays on and there is no abs functioning
Any ideas????
Thanks
Rinus (netherlands)
Old 11-16-2016, 02:20 PM
Re: strange abs light
It could be the ABS computer under the seat has failed.
Old 11-18-2016, 07:26 AM
thanks
only solution is buying a new one??
Rinus
Old 11-18-2016, 02:13 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Rinus,
If you send me an email address, I'll forward the Service Manual chapter on the ABS system which may help you track down the problem. When my ABS module failed, it flashed a code 10. Seems like yours isn't getting any power or has suffered a "catastrophic failure"
Old 11-18-2016, 02:21 PM
Check Ebay, I got one on there.
Old 11-20-2016, 06:41 AM
SVXNATION's Avatar
SVXNATION SVXNATION is offline
SVXNATION
Not sure if this has been sorted by now or not but we do have a running thread on the svxnation facebook group with several solutions that might help.
Come Join The Nation
We are a combination of both the Network the Forums and a plethora of new bloods! We have close to 6000 members on all forms of social media worldwide. What's all the fuss about? We're just the next logical step in a social media-driven World! As one of the community's longest-running members explained: If the the traditional forums are the library... SVXNATION would most certainly be the popular corner coffee shop
www.svxnation.com
Old 12-06-2016, 10:39 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
http://www.jauce.com/search/subaru+svx
much cheaper than Ebay
