Old 07-20-2016, 04:56 PM
rj7630 rj7630 is offline
Head repair.
I have a cylinder with low compression. Not sure if it a head gasket although water temp is fine, no coolant leak that I can find and no white exhaust. So likely a valve problem. Does anyone know a shop in the Portland Oregon area that is good with Subaru motors?
Thanks
Old 08-20-2016, 12:25 PM
Re: Head repair.
i am not from the area but would recommend a leak down test to find out where you are losing compression. could be valves, rings, etc.. but without knowing for sure you will just be throwing parts at it. do a wet compression test, could be a stuck ring.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
