A/C Idle Pulley Disintegrated
My idle pulley assembly for the A/C has fallen to pieces (bearing assembly slipped out), shredding the belt and pushing the pulley into the timing belt cover. It wore into the cover, and wedged into the cover about 1/2 of the thickness of the pulley. My question is: normally how big is the hole behind that A/C pulley? I looked at an illustration at SubaruParts.com and see that there is supposed to be a hole there (see my profile picture for which hole I'm talking about), but if it is just supposed to be a small hole I probably should replace the cover. The hole in my cover is now as big as the pulley.
Searching the threads, I've found where this happened to a few other people, possibly because the bolt wasn't tight (though I think mine was when I took it off) or the pulley was on backwards somehow. Or maybe it just wore out. Anyway, I think I'll be replacing the whole pulley assembly. Anyone have one they want to sell?
--Ross (earthkin) RIP: '92 SVX LS-L AWD, black over claret Nearly gone: '92 Legacy SW, 353k miles '00 Impreza Outback Sport, 'silverthorn met titanium,' 134k miles |
I don't recall any hole in the timing belt cover behind the AC idler pulley. It probably wouldn't hurt anything to postpone replacement of the cover 'til the next timing belt service.
dcb |
There's not supposed to be a hole behind the A/C idler pulley. The place you're indicating on the drawing is a partial convex dome over the water pump pulley.
A hole in that cover may not be so bad for a short while, but you should make sure there is no debris from the A/C pulley and belt rattling around the timing belt. You can remove all of the front timing belt covers fairly easily (you'll just need to remove the outer crankshaft pulley and the tensioner under the P/S pump). It's not nearly as bad as removing the crankshaft gears [correction — camshaft gears] . You may find that you only need to clean and vacuum out the timing belt area. Then you might get by gluing on a cover plate over the hole. On the other hand, if your timing belt has been chewed up, you may want to go ahead and replace it.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses Last edited by SVXdc; 10-04-2007 at 09:33 AM. |
Ok, no hole should be there...
Okay, now that I look at the SubaruParts.com illustration again, I realize that the "hole" it shows is in a different position, shown located on the horizontal lines on the cover (mine is up higher). So my latest thought is fabricate a temporary plug that I can glue in place with plastic-epoxy until the next timing belt change. I'm a little nervous about leaving the hole there because I'd like to get my engine steam cleaned (old oil leaks have left some serious grease).
Thanks, Ross
Debris?
The timing belt looks clean. The pulley wheel hadn't quite gone back far enough to damage anything (I have a real nice view hole now to look in! - so I'm inclined to just crank the engine several times and look over the belt). Wouldn't any debris just sit on the bottom-inside of the timing belt cover? The timing belt was fairly new - if an error was made with the gear it was probably the mech that replaced the belt that did it, though I couldn't swear to it since I think I had the A/C belt replaced later.
I'm a pretty basic-type mech (you probably guessed that by the fact that I hired someone to replace the belt), so I'd like to avoid removing or replacing the center cover myself.
If it were my car, I'd pull the covers to make sure the timing belt chamber is clean and look over the entire belt. It's not that hard. With the A/C belt and tensioner off, you're already 1/3 of the way there. Until recently, I hadn't done much more than change my oil myself, but a couple of weeks ago replaced the water pump (which required removing and reinstalling the timing belt). See this post (#9) for helpful links. BTW, the "Unorthodox Racing Pulley Installation" guide includes a picture of a new front timing belt cover. You'll just need a helper to lock the flywheel while you remove the crankshaft pulley, then a big torque wrench to bolt it back on. Find a friend who's done similar car work and offer some beer and/or pizza.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
Guess I'll have to do the work...
Okay, David C, I guess you are right about checking for debris. There were some wicked metal curves off the race for the bearing -- probably enough to slice the timing belt at high RPMs if any got in with the belt. Thanks again. I'll just have to tough it out. While I'm at it, maybe replace the cover, too.
I'll check out the link.
probably the idler bearing just wore out
[QUOTE=earthkin;497765]The timing belt looks clean. The pulley wheel hadn't quite gone back far enough to damage anything (I have a real nice view hole now to look in! - so I'm inclined to just crank the engine several times and look over the belt). Wouldn't any debris just sit on the bottom-inside of the timing belt cover? The timing belt was fairly new - if an error was made with the gear it was probably the mech that replaced the belt that did it, though I couldn't swear to it since I think I had the A/C belt replaced later.
there would be no reason to disrupt the idler and bracket that controls the tension on the ac belt to replace either the ac belt or even the timing belt. However we never know if our "mechanics" would know that. It is simply removed as a unit if necessary or just loosen a couple of bolts and retighten to replace the ac belt. The idler bearing does wear out but should make an audible sound as a warning before it comes apart. Much better to replace the cover and get it sealed properly. Good luck Keith. Last edited by kwren; 10-04-2007 at 11:32 AM. |
Bearing wore out...
Sounds like you are right about the bearing just wearing out. My daughter had complained about the noise, which I thought was the A/C compressor. I had her take it into a shop near where she goes to college, and they said the couldn't hear the noise! Maybe too much time on the firing range, because it was pretty obvious to me. Then about a week later, she drove it home and the A/C stopped working (that was when the bearing disintegrated, I'm sure). Darn mech! It would have been pretty easy to fix if they'd bothered to investigate.
I told her to never take it back there. Fortunately, all they actually did was an oil change, and it hasn't leaked out yet (hopefully they didn't strip the plug bolt!).
