Old 03-27-2009, 05:41 PM
Famouspork Famouspork is offline
fans not working
I rarely get stuck in traffic.
Today, I did for 10-15 minutes. Enough for the temp guage to go up close to the red zone. So I chacked all the fuses and relays, one of them was corroded.I them switched it for the AC relay hoping to find the problem.They just wont start.I am definitely pissed. thermostat? temp sensor? Where is the tesmp sensor? the fan connectors are fine, the fuses are ok too. I can't believe it.
I read posts where fans won't stop, but none where they won't start.Another post mentionned something about the 20 amp cig light fuse beeing the culprit for many problems.I know mine don,t work, but I could never relate that and the rad fans not working.
Is there a way i can just bypass the system and have a switch to turn them on and off as i please?
Old 03-29-2009, 09:09 AM
Re: fans not working
Hello all!
I am quite worried about this problem, my fans are not working, the lectrical circuit apaprently works..could it be my thermostat?
Old 03-29-2009, 09:13 AM
Wikedjuggalo's Avatar
Rebuilding
Originally Posted by Famouspork View Post
Hello all!
Not to my knowledge. Check all fuses in your car, Physically pull them out and look at them. Make sure your fans are actually plugged in all the way.
Old 03-29-2009, 01:51 PM
Actually, the fans are connected, the thermostat is ok. The AC doesn't seem to work either.I tested various fuse poerts with my multimeter this morning, and the 2 fuse ports for the 25 amp fan fuses do not give any reading.The fan connectors don't get any juice . I wonder where is the missing link here. I'll look at the electrical diagram, but if you know anything about this, please let me know!!
thanks
Old 03-29-2009, 01:57 PM
kwren's Avatar
kwren kwren is offline
Maybe the fan motors are bad??
It happens
Old 03-29-2009, 10:59 PM
Both of them?
The connecteor that lead to the fans are not getting any voltage
Old 03-30-2009, 09:21 AM
stuartracing stuartracing is offline
Same thing happened to me...The rad. wasn`t getting hot on the bottom, top was hot....Changed the therm. , water then started circulating through the rad. and fans stated working again, and the a/c worked too....Now it`s doing it again, but when I changed the t/stat I used a gereric one from autozone.....Going to the SUBARU dealer and get the stock one....
Old 03-30-2009, 09:39 AM
kwren's Avatar
The reason I suggested maybe the fan motors were bad, not the chances that both would go bad at the same time but the possibility that one could go bad and you wouldn't necessarily know it. If the other one went bad, sitting in traffic would bring that to your attention.
It happened to me.
Keith
Old 03-30-2009, 01:29 PM
How much does a relay cost in average?
Old 03-30-2009, 01:36 PM
kwren's Avatar
There are 5 different relays involved in controlling the cooling fans.
Are you going "pot luck" and start buying relays when chances are the relays are not even the problem
A Subaru dealer can give you the prices.
Keith
Old 03-30-2009, 02:06 PM
Keith
Not my usual M.O., but that would be one step forward.
I think they cost around 7 bucks
Old 03-30-2009, 03:04 PM
kwren's Avatar
there isn't any one relay that will keep both fans from working
Old 03-30-2009, 03:10 PM
kwren's Avatar
do you know how to test the fan motors?
Old 03-30-2009, 03:12 PM
kwren's Avatar
and the MFI control module?
Old 03-30-2009, 03:15 PM
kwren's Avatar
And the 3 fuses?
(one 10 amp and two 25 amp)
