DIFFERENT seatbelt problem
OK! solved at least one problem with the seatbelt. a connection I was unable to see last time in the drivers door. then I manually brought back the seatbelt, and it worked for half a day. then it went to the rectracted posistion, and stayed there. I already checked all the connections to the motor itself, and it can't possibly be those. any other ideas?
seatbelt help
The above link should help you. Dose your seatbelt fire when the car is running? Have you checked your seatbelt error codes? Have you used a voltmeter to check to make sure your forward, and retract limit switches are indeed working correctly? Your problem was very vague. Please explain more |
