Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 11-10-2006, 03:45 PM
Dessertrunner's Avatar
Engine Torque Control Signal how does it work.
Could some one explain to me what and how the Engine Torque Signal Works understand it is to reduce torque when transmission changes and with throtle closed it and in Netrul is +5V. What is it at full power not during a change?
Tony
Old 11-10-2006, 05:37 PM
Ahve a 5 speed and put switch between pin 16 torque control and 5 v and got no difference in power. Also messured the voltage on the ECU end of 20 and got 5 v anyway so tell me does the pwer come from taking pin 20 to 5 v or ground because I don't seem to be able to tell. Haven't tried grounding 20 as not sure if safe.
Tony
Old 11-10-2006, 07:21 PM
oab_au oab_au is offline
Tony
Tony the line from the TCU is held high, 5V, when the TCU wants Torque cut, it pulls the line low, 0V. I think most just leave it unconnected. I would wire it to 5V, to prevent it from giving any problems. Of course where you can get the 5V from,,,,I'll have a look and get back.
One Arm Bloke.
Tell it like it is!
Old 11-10-2006, 09:27 PM
Harvey that makes sense and I don't think you have to connect it as the ECU reads 5V standard so that explains why connecting to 5 V did nothing. You may be right to leave it alone.
Tony
Old 11-14-2006, 08:13 PM
longassname's Avatar
Just some dude.
Significant Technical Input
Actually, I don't believe the tcu holds the signal path high. I believe there is a pull up circuit in the signal path in the ecu. The pull up circuit makes it un-necessary to connect it to a signal source to prevent the circuit from floating.
Old 11-14-2006, 09:03 PM
dynomatt dynomatt is offline
Can you explain that a bit more for the nuffies like me?
Old 11-15-2006, 02:06 PM
Trevor's Avatar
Trevor Trevor is offline
This instruction is bad news.
As has been clearly and wisely stated on a basis of logic, it is highly undesirable in this instance to apply a voltage to the incorporated divider network.
Trevor, New Zealand.
Old 11-15-2006, 02:30 PM
This post shows that, the reader has no idea, what we are talking about.
One Arm Bloke.
Tell it like it is!
