Old 02-05-2009, 05:24 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
ABS light came on, with under-hood noise!
Twice now since I did all that cleaning under the hood, I've had my ABS light come on. Both times it's been as I'm pulling into work.
The first time it happened was on Monday (IIRC). The ABS dash light came on so I parked and turned off the car, I heard some buzzing coming from under the hood, so I popped it, and sure enough the ABS control block was purring (even with the engine off and the key out of the switch). I pulled the big old ABS fuse out, and the buzzing stopped. Reinstalling the fuse seemed to reset the ABS and the light didn't come back until today, when the ABS did the exact same thing, and I ended up having to pull and reinstall the fuse again.
I'm wondering if all the water and oil eater from hosing out of the oil in my engine bay may have made the ABS unhappy, or if this is a common issue and someone may know what's going on.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 02-05-2009, 05:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: ABS light came on, with under-hood noise!
It sounds like it's sticking. Just lightly tap it with something.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-05-2009, 05:41 PM
oab_au oab_au is offline
The relay under the black cover, needs replacing.
I think it is a common Bosch relay.
One Arm Bloke.
Tell it like it is!
Old 02-05-2009, 05:46 PM
sperry's Avatar
That sounds easy enough... plus a dead relay sounds on par with something that might happen when you introduce a pressure washer to the inside of a 15 year old car.
Old 02-05-2009, 06:36 PM
Green1995SVX's Avatar
It can be replaced with a standard Bosch style relay which you can pick up at Radio Shack. 30 amp automotive relay part number 275-226 ($6.79).
http://www.radioshack.com/product/in...ductId=2062477
In the meantime, you can give the top of the box a brisk tap with your hand. This will stop it from running.
If you'd like to go with a genuine Subaru part, the part number is 26735AA012 from the subaru dealer. It retails for $51.45.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-05-2009, 09:16 PM
oblique_03 oblique_03 is offline
I occasionally get this in my car. Its not a big deal, i just pop the hood and give it a thump. But one day my girlfriend borrowed my car and parked it overnight with the relay stuck...battery died, I was a few minutes late to work in the morning....
Thanks for the part number greeen1995SVX, you just saved me some money. I will go to radio shack tomorrow.
Hal
Old 02-06-2009, 11:16 AM
sperry's Avatar
Well, one trip to Kragen, 6 bucks, and 30 seconds under the hood and hopefully my ABS is fixed.
I guess I won't know for sure since it was an intermittent issue, but from the feedback here it certainly sounds like the relay was all it needed.
