Old 05-29-2005, 09:25 AM
~*~JenSVX~*~'s Avatar
~*~JenSVX~*~ ~*~JenSVX~*~ is offline
J. Bond
Send a message via AIM to ~*~JenSVX~*~
Converterer Locking up
OK so a few weeks ago i had this problem and everyone told me it could be the converter locking up... but then the problem went away so i was hoping it fixed itself... But now it's back and i've been told its the converter locking up by the guy that changed my alternator... Only thing is that he doesnt know how to fix it... Can anyone give me an idea as to where to point him or what to do? Any help is appreciated!
Jen
J. Bond 7
1994 Laguna Blue
www.longislandsubaruclub.com
LISC member #50
Old 05-29-2005, 10:10 AM
n00b on demand's Avatar
What was the original problem?
Old 05-31-2005, 12:54 PM
Just like I mentioned in the other thread...have you ever changed your Engine Temperature Sensor?
Old 05-31-2005, 01:37 PM
Are you stalling out?? The converter locking up would cause quite a stall adn jerk the car( much like dropping the clutch out on a 5mt(ive never done it )) Anyway stalling could be many things from tps to a bad reading from a cam angle sensor. Check it out and let us know
Old 05-31-2005, 03:26 PM
drivemusicnow's Avatar
Poor College Racer
If someone can find a tranny pin-out diagram that would be mighty helpful. If we can, you could tap the lock up clutch wire and read voltage when you think the converter is locking up... this would quickly and cheaply condemn or eliminate the TC locking up as your problem.
If after checking the voltage and you find out that it is in fact the TC locking up, then do as David suggested and try the engine temp sensor.
Some questions i have... Does the SVX 4eat have its own tranny temp sensor? (it has an idiot light for it i believe) I would hope it does...
The reason temp could cause this, is because the torque converter is the largest source of heat in the transmission. therefor, if the TCU thinks the tranny is hot, it may have "logic" built in to try and close the converter as often as possible, thus eliminating the heat source.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 05-31-2005, 05:06 PM
What temp does the tranny have to get to for the light to go on anyway?
Old 05-31-2005, 05:22 PM
immortal_suby's Avatar
Thread Killah
If you see it the tranny is already dead. I have buried the needle on my tranny temp gauge and not seen the light. It was over 240.
Locker Link
2015 BRZ Limited 6MT
Old 05-31-2005, 10:01 PM
J. Bond
Well i think tomssvx has pretty much got it... I'm actually headin out to the dragon tonight... Hopefully there will be some masterminds there that want to take a look at it! I'll let everyone know how it is when i get back next week.... Wish me luck!!
Jen
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 05-31-2005, 10:27 PM
Rd96SVX's Avatar
Rd96SVX Rd96SVX is offline
antidisestablishmentarian
Send a message via AIM to Rd96SVX Send a message via MSN to Rd96SVX
you'll be at the dragon?!?!?!??.. hmmm, ditto.. hopefully we'll get that figured out for you. Looking forward to seeing you there. I'll be there friday. I'll post a link in the southeast thread so we can be thinking about it.
-Alex
1996 Brilliant Red LSi "Allie"
+226k mi.
25,000 lb GVW Trans-Cooler
Wet-sanded "cleared" Headlights
Charcoal 22% Tint
Removed intake resonator
'95 Probe GT Wheels
'97 grille
"New Addition" 1992 Teal LS-L
+156k mi.
Status... Reconditioning
