Old 05-05-2005, 07:08 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
clunking
i have an annoying clunking under the front end when i hit small bumps. i figure it's either bad struts, bad control arm bushings, or bad strut mounts. however, it's a different sound on each side. the right does it when i hit a bump (no matter how small, kinda like a rattle) and the left makes a horrible sound when i pull into a driveway makinf a right turn and hitting the bump (kinda like something binding the snapping into place).
does anyone know how i can test my strut mounts? i pulled them out not long ago and there were no signs of wear but that would remain the same with the control arm bushings (not cheap by the way).
any takers?
Old 05-05-2005, 08:21 PM
mbtoloczko's Avatar
sans SVX
If you pull the strut mounts and check them out, you might find that the bearing race is very slightly notched, but other than that, there is nothing tell-tale.
Mychailo
Visit my locker
Old 05-06-2005, 10:34 AM
Grab each tire and shake (wiggle) it side-to-side and top-to-bottom. You may be able to reproduce the rattle.
Side rattles are related to steering.
Top rattles are suspension related.
