Charging A/C System
I've done some researching before posting however am still a little confused about the charging process for a 92 SVX a/c system.
Background: I am replacing every component within the a/c system (Compressor (rebuilt); lower pressure hose (muffler); High pressure hose from compressor to condensor; condensor; high pressure line with trinary switch from condensor to drier; new drier and new expansion valve. I will be flushing the high pressure line from the condensor to the evaporator and the evaporator itself (these are the only two parts I am reusing). So my questions concerns are: 1) The manual states to initially charge through the high side (with engine OFF) while in liquid form? I am not all too familiar with this but my can of freon seems to be in liquid form? the only reason I bring this up is because once a can is used up on the high side, the manual states to finish charging on the low side with remaining freon in vapor form??? From what i've read a lot of systems charge only on the low side, why is this different on the svx? 2) I need to purchase a vacuum pump, does anyone have any suggestions? 3) I am sticking with r12 and need to use compatible oil for the compressor and fittings throughout the system. What type of oil should i be using? 4) Anyone have a set of r12 gauges they would be willing to lend or sell? 4) Has anyone installed an in-line a/c filter? I did a little research on the internet and some of these require cutting of the OEM piping...not too fond of this idea. Thanks in advance for any help/suggestions, thanks Chris |
Re: Charging A/C System
I am very interested in someone knowledgable on this subject too. I disconnected one of the lines to the a/c compressor while removing my intake and I believe I have to recharge the system now.
I don't know if it matters—probably not—but be mindful that a reman compressor may be intended for an r134 system.
dcb |
Funny enough, after searching the forum's I went with your suggestion and get a reman from 1airconditioning. The instructions indicate that the oil used is compatible with both r12 and R134a systems. That and the reman is specifically for a 92 model. So I think i am set on that front.
Y are you staying with the old r12. iT WILL BE HARDER TO GET EVERY YEAR. bOTH MINE HAVE BEEN CONVERTED AND THEY BOTH CAN FREEZE ME OUT OT THE CAR. sORRY SHIFT LOCK STUCK
kEITH |
I personally would evacuate the system, close the port and remove the vacuum pump, connect the hose to the high-side from the inverted refrigerant can, open the high side port and charging port on the can to get as much as possible of the liquid in the system, when this is accomplished, close the "high side valve and close the valve on the can, start the engine and set climate control to allow the air condition compressor to come on, then connect the hose to the low side and slowly put the rest of the liquid refrigerant in the system... as instructed with the charging kit. This is of course with the proper charge size of refrigerant.
You are to be commended for attempting this project and I'll bet you can pull it off!! Keith |
Hope this helps. Keith |
