ECU swap: OBD2 for OBD1?
Has anyone thought of doing this? Would it be plug and play, or is the wiring harness/connectors different for OBD2? I'd like to run an ECUtune Stage 1 chip in a '96, but of course it's not made for OBD2. Could I swap my ECU for a pre-96, I wonder?
Re: ECU swap: OBD2 for OBD1?
change the TCU as well.. It can be done.
Tom |
what about the other way around?
No, there were additions to the OBDII systems that the OBDI's do not have. BUT everything from an OBDI system is and should be present in an OBDII
Tom |
Do you need to swap the TCU when swapping a OBDII engine and tranny into a OBDI car. My OBDII tranny shifts smooth as butter in my OBDI car. Just thought Id ask
1995 POLO LSI 76K MILES SOLD |
No because you are using an OBDI ECU... There is communications beyond the OBDI standards between the OBDII ECU and TCU. If you change one, it is suggested you change the other as well.
Tom |
