littlefuse holder Q:
How is the littlefuse holder mounted to the fuse box in the engine bay?
Re: littlefuse holder Q:
The Fuse holder is pop-riveted to the bracket. Put the rivet in from the rear and compress it from the front. Check the photos closely. Refer to this post HERE It is a part of the "Alternator Wires" thread. Click HERE .
OK so i could take duct work tin. paint it black so it doesnt look like i rednecked it. drill two holes for the megafuse holder placing it on the tin and marking it with a nail so i know where to drill the holes put rivits in the tin not in the fuse box. so i dont drill in to my fuse box nice!!! i didnt want to drill into my factory fuse box anyway i like to keep things as a orginal as i can!!!!!
Q" do you bend it so it bottoms out inside the fuse box for stablity. or do you just bend enough so it just catches? have you had any problems with it radaling? or staying in place? how long does this mod take from start to finish? Do you crimp your end connectors or do you sauder? i plan on cutting the lenth of the cables i need first, then doing the crimping or saudering outside of the engine bay... the factory negative ground cable is no longer need? and have to strip the negitive battery connector off with out damageing the copper what works best for doing that? why did you mount the new 4 gauge ground cable to the horn bracket and not where you remove the factory ground cable? thanks again for all your knowlege that you bring to this form... Last edited by kjoyes; 10-11-2011 at 12:24 AM. |
oh ya sorry with the bunbardment of same old questions will try to do a seach before posting!!!!!!
I plan on doing this mod with the factory alt. untill i get enough money to buy the 160amp one. but it will give me peace of mind when i go out to start my car in the cold winters of minnesota. Last edited by kjoyes; 10-10-2011 at 11:54 PM. |
I just finished up this modification... and I considered doing what SVXCESS did with his fuse holder.
But I decided to do something slightly differently. I mounted the fuse holder to my battery tray. (the plastic shell that the battery sits in, that has sides toward the engine, and toward the front of the car. SVXCESS's car doesn't show that he is using one with his optima, and I imagine some SVXs may no longer have their original battery trays. But if you do, I can tell you how I mounted mine. I have pictures, and I'll try to get them posted up tonight. I positioned the fuse holder vertically on the outside of the tray wall. It is centered vertically, and mounted just slightly forward (toward the front of the car) of where the positive battery post is. There is a shape-change on the tray wall, and I aligned the fuse holder to sit right along side that. It basically fits on the car between the oil filler cap, and the positive battery terminal. Basically it is as easy as mocking up it's placement on the car, to make sure there is clearance... Scribe the mounting holes of the fuse holder onto the plastic of the battery shell, and drill them out. (of course off the car, without the battery in the tray. ) I then fixed the fuse holder to the battery tray wall with nylon license-plate frame bolts and nuts. Nice and non-conductive, and plenty stable enough to hold the fuse holder in place, and removable later, if necessary. I fed the bolts from the battery side of the tray, with the nuts tightened down on the fuse-holder. The thin bolt heads don't impede the battery's placement at all. The 4-gauge wire from the alternator fastens to the top fuse post, and then I made a ~14" 4-gauge lead from the bottom fuse post, that turns and comes up to meet the positive battery terminal lug, along with the starter lead, and the smaller lead to supply the fuse box for the rest of the circuits in the car. I'll try to upload my clearer build-pics later. The currently attached photo shows the finished work. The fuse holder is not visible, but it is down along side the battery between the battery hold down, and the positive terminal, in the space between those and the oil fill cap, and the AC pipe. There is clearance there without touching the corner of the valve cover.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. Last edited by BoxerFanatic; 10-11-2011 at 11:41 AM. |
This is a drawing of the rear of the bracket that I made. I could not post it in the alternator wires thread as I had the maximum number of attachments.
Inside the gap in the front of the fusebox there is a thin, raised vertical rib of plastic that will keep the bracket from sliding down completely. Just cut a small notch on the bracket to slide down on either side of this strip. This will also act as a key and keep the bracket from sliding side-to-side when the fuse box cover is attached. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-12-2011 at 05:31 AM. |
I have another question about the megafuse holder, fuse is between altenator and the battery.
I want to add subs do i still have to put a inline fuse on the amp power wire going to the trunk? |
