HELP! 430 miles from home...
So I drive my SVX all the way to Reno from so cal.... makes it all the way no problems. It sits for a while, cools all the way down..... I start it up, its fine for about 60 seconds until i make a hard left turn onto the main street, where it stalls out and wont start. It cranks fine, I looked under the driver side timing cover, the belt is on and seems tight. I can hear the fuel pump come on with the key..... it just died after the turn and now wont start! Does anyone have ANY possible ideas on why this may have happened after a cooldown following a long drive? I wasnt stressing the motor when it happened.... was just driving normally turning left. Im stuck here until I can fix it Thanks
Re: HELP! 430 miles from home...
Sucks. MAF plug maybe?
I am betting on one of the sensors going... Crank Sensor...
Had that happen to me... same signs... everything fine one second... next its dead. -Sov13t. |
Any check engine light? I would probably check codes and if that comes up negative, would probably pull a line from the fuel filter and do a quick on/off with the key and see if you are getting fuel.
1992 Subaru SVX 5spd 1998 Pontiac Firebird Formula 1999 Chevrolet Camaro SS 2009 Subaru Forester - Mileage Junky 2009 Pontiac G8 GT 2017 Ford Mustang GT 6spd |
that sucks!
check all the connections, i would guess it is a sensor of some sort.... well, if all fails u might have a potential buyer here.... my homebase is in auburn ca, about 100 mi from reno good luck! i hope you find your gremlin and get home! |
I would go with crank angle sensor, cam sensor, or temperature sensor. Mine was very intermittent until one day when it decided it will never start again. Then it was time to replace the sensor and all was well again
yeah, what Tim said...
-Bill
Thanks for the replys you guys, ill check that stuff first thing tomorrow. It just had to be raining tonight so I cant do much now with no covered parking.
