Old 12-28-2013, 12:30 AM
Re: oil leak on top of motor
If they don't, it can be installed afterward.
Old 12-31-2013, 09:21 PM
SUPER SUPER is offline
Well, started the project. Vacuum hoses hard as a rock. Connectors cracked. Check valve crumbled, etc. I ordered some more more parts. Anyway, it looks like the oil is coming out of the center of the IRIS valve I did not take it off the manifold yet. Could this leak be because the PCV valve was backed up? or do I have a bigger issue with the IRIS valve?
Old 12-31-2013, 09:39 PM
I do not know of any bushing/seal/O-ring to seal the factory shaft IRIS shaft.
However if you replace the IRIS O-Ring, that should take care of most of the vacuum leak/oil leak.
Otherwise it will need an IRIS valve.
For the record, I have never bought a new one from Subaru.
Old 12-31-2013, 09:54 PM
OK thanks. Maybe the IRIS valve is fine. I am hoping for the best. Subaru is really proud of their parts. I can just imagine what that would cost...
Old 12-31-2013, 10:03 PM
I am having trouble finding an IRIS valve on the subaruparts.com site. Does anyone have a part # or link?
Old 01-01-2014, 08:50 PM
Is the IRIS valve the same as the Induction Control Valve?
Old 01-02-2014, 07:20 PM
http://www.subaru-svx.net/photos/user.php?svxfiles|29830
Look in my old locker under I.R.I.S. valve...
Old 01-02-2014, 10:47 PM
Here is a picture of the valve assembly as it sets.
Old 01-12-2014, 11:22 AM
It is all back together. No leaks so far. Just a warning for anyone that decides to replace original vacuum lines, be prepared to replace most of the expensive components that are under there. Lines rock hard and nipples brittle. snap. snap. Anyway, I am glad it is done.
