Re: oil leak on top of motor
PM sent re o ring
Thanks to the more experienced folks for chiming in. I had oil pooling on top of the motor + a code for a bad knock sensor, at ~150K miles on my car. Both were cracked. I assumed their replacement was a given while the intake was off, at least on any motor with 100K+ miles. But maybe that was just my car.
And I didn't know about the IRIS O-ring at all! Oh well, maybe next SVX.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
Thanks for all the knowledge and suggestions. Parts ordered. Will dig in when they arrive.
Got the o ring for the IRIS. Is there a diagram on the site that shows where this goes?
If you have the alternator removed you MIGHT be able to replace it while the intake manifold is still installed on the engine. Be prepared to use words that would have your parents wash out your mouth with soap. It is only four 12mm bolts (outside wrench diameter) and one link to deal with, but what a PITA!
While the intake manifold is off the iris valve is much easier to deal with. |
In the above picture the I.R.I.S. valve, (not the IRIS check valve) is next to the can of WD-40, sitting on the paper towels.
Oh, and IF you take off the intake manifold its a GREAT time to change the $3.00 PCV valve. I might have said this before, but, hey, I'm old...
So, when u take IRIS valve out to replace o ring, do you do anything with the valve while it's out? Clean or lube?
Cleaning it would be nice.
As far as lubing it... The shaft pivot points get no lube, other than engine oil vapors from "The Factory". If it is worn to the point of noticable wear, maybe you should just replace the IRIS valve assembley, (but it's like $300.00)
PCV valve was a huge PITA. I think mine was overtightened, or the aluminum fused with the metal, but there was no way I was getting mine off without the manifold off and some major elbow grease. A side benefit: the SVX runs happier with less vacuum leaks after replacing the brittle/cracked hoses . Really long needlenose pliers go a long way in this project.
#28
Hoping to get started. Should I order the check valve too? |
#29
and can EASILY be broken. If it has a crack in it (quite common) then it will fail. They can be replaced without removing the intake manifold. I use 12" long hemostats , a head lamp, cause my eyes are old... lift the car seversl feet in the air, again cause I'm old... But, HEY, while you are down there.
#30
Hopefully the local dealership has one... don't want to wait for shipping.
