Old 06-14-2016, 02:31 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
EDM headlights
There must be a few SVXs in Europe/UK that are in wreckers?.
I've picked up the EDM set of headlights & the adjustable tilt switch.
What I require is the mating connectors for all 3 connectors.
Behind each of the headlights there will be 6-pin connectors.
In the center consolde area there will also be a similar connector.
I require all 3 connectors (plus a bit of wiring).
Just in the process of adding the fog lights into these units.
Thanks
Steve in New Zealand
surteess@xtra.co.nz
Old 06-18-2016, 03:31 AM
SURTEESS's Avatar
Re: EDM headlights
Old 06-18-2016, 03:32 AM
SURTEESS's Avatar
Re: EDM headlights
adjustment switch
Old 06-22-2016, 05:35 PM
Re: EDM headlights
Rear deck blower. How much? PM $$$$ amount
Old 06-23-2016, 05:17 PM
SURTEESS's Avatar
Re: EDM headlights
Sorry don't have one for sale (but might have one later in the year from a JDM wreck coming in to NZ).
