Old 09-14-2005, 12:10 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Unhappy
Sorry to hear about this.
Glad that all persons involved are okay and be grateful that it's not worse that this.
Hope you can get that svx fixed for a best rate soon......
I can't wait to see that beautiful svx pics again
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 09-14-2005, 10:43 AM
Originally Posted by US to CDN SVX
I once swerved to avoid a deer like thing lying in the middle of the road in my sisters RX-7 going across Texas and did about 3 or 4 360 spins. The nose is so low on the SVX that if you hit the deer upright it could have gone through the windsheild and killed your dad. Yikes. No burns to the arms from the air bags?
Glad your dad was alright.
I was very impressed with the way my SVX handled the maneuver. I yanked the wheel and the SVX just said, "OK" without whine (wheel noise) or hesitation.
The passenger in my dad's car actually had a burn on the tip of his nose as well as he got some of the powder in his eye. They took him to the hospital and they also said he had a slight abrasion to his cornea.
Old 09-14-2005, 10:47 PM
US to CDN SVX's Avatar
US to CDN SVX US to CDN SVX is offline
SVX Voyeur
Not bad really. Most people I know who have had their Air bags go off on them burn the insides of their arms. (Other Makes)
Another thing that sold me on the SVX was when my Grandpa took me into a parking lot in LA, 1st rain in months, was going 60kms and he said crank it left. The car turned as I held on. That is what scared me when my sisters RX7 spun so out of control. No AWD there. Rotarys in more than one way
1992 SVX LSL Peacock 94,000Miles
1981 VW Westfalia 166,000Miles
1995 Volvo 850 Wagon GLE 174,000Miles
1981 FIAT Spider 120,000Miles
50% Boxer
Old 09-19-2005, 11:23 AM
So my dad called me right before I left work work and was able to give the following list of parts he wants before I had to leave:
Valve cover gaskets w/grommets
2 cam seals
timing belt cover (2 rear ones) 13569aa060, 13532aa002
timing cover dust shield pieces (4 parts)
timing belt 13028aa120
both motor mounts
A/C condenser
both air bags
both airbag sensors
Cooling shroud ?
radiator
radiator supports (5 pieces)
both rad hoses
both rad fans
bottom engine cover
windshield
More (I assume) to come.
Old 09-19-2005, 11:58 AM
ilsegretosvx
I have 2 drivers airbags. I'll look for the sensors. I might have the condensor also.
Old 09-20-2005, 04:44 PM
I totalled up how much these parts (and a few extra parts for me) would cost from 1stsubaruparts.com and right now we're sitting around USD$5000. I'm sure there's stuff I missed though.
Old 09-22-2005, 02:53 PM
So here's the list so far (this includes stuff for my car and any other local SVX's that need parts)
Total = $3854.37 (we are getting the windshield locally)
Code:
2	13270AA031	RHS rocker cover gasket	20.08
2	13294AA020	RHS rocker cover gasket	11.44
2	13294AA030	RHS rocker cover gasket	11.44
2	13272AA031	LHS rocker cover gasket	21.52
2	13293AA011	LHS rocker cover gasket	11.44
2	13293AA020	LHS rocker cover gasket	11.44
40	13271AA051	rocker cover washer	84.8
2	806732050	camshaft oil seal		11.54
1	13532AA002	RHS rear timing belt cover	30.9
1	13533AA002	LHS rear timing belt cover	24.72
1	13560AA010	LHS front timing belt cover	26.76
1	13584AA090	RHS timing belt cover seal	13.64
1	13586AA060	LHS timing belt cover seal	8.3
1	13587AA000	timing belt cover seal	12.34
1	13597AA010	timing belt cover seal	12.34
1	13028AA120	timing belt		71.96
2	ST4100055110	RHS engine mount		113.8
2	ST4100055120	LHS engine mount		113.8
1	45199PA001	radiator			335.96
1	73020PA021	A/C Condenser		230.36
1	98211PA030MD	RHS airbag		725.28
1	98211PA003MD	LHS airbag		587.99
1	98231PA000	RHS airbag sensor		259.19
1	98231PA010	LHS airbag sensor		269.19
1	45167PA000	upper radiator hose	9.6
1	45167PA020	lower radiator hose		9.6
1	45137PA000	radiator fan shroud		59.29
1	45121PA001	radiator fan		165.56
1	56410PA001	bottom engine cover	142.74
1	73040PA001	A/C fan			155.95
1	45137PA010	A/C shroud		74.14
1	53060PA040	lower radiator frame	71.96
1	53040PA000	hood lock			34.51
1	66038PA110DO	LHS console cover		13.99
1	ST4100055200	STi transmission mount	65.48
1	41322PA000	rear diff mount		31.32
Old 09-22-2005, 05:08 PM
ilsegretosvx
so out of that list what do want used? I have a bunch of that list
Old 09-22-2005, 05:22 PM
I'll let you know once I place the order with 1stsubaruparts.com as since we're not paying for it it may as well be new.
If there's anything they can't get I'll be sure to let both you and Mike know. Mike wants to keep his old car on the road
Old 09-22-2005, 08:08 PM
Green1995SVX
Wrong part number... you want 66038PA110MD - DO indicates beige color.
Mike
Old 09-23-2005, 10:15 AM
Yes I am aware of that. That's for a 97 SVX. We broke that piece installing a stereo.
Old 09-25-2005, 09:16 PM
svxstarship svxstarship is offline
Don't forget the airbag control module. It's under the radio. I just changed both airbags and the module today. I did not change the 2 front sensors as they were not damaged. Airbag light is no longer on. Good luck.
Old 09-26-2005, 11:53 AM
Thanks for the tip. Does the control module need to be replaced? It wasn't mentioned in the damage report but I was curious about this.
Old 09-26-2005, 12:36 PM
Yes I believe it does. When I received my airbags I was suprised to find this included. It was mentioned to me that there might be a place in Toronto where it can be reset. It is somewhat hidden under the radio by a piece of black vinyl. I have an interesting link in relation to this, but it's at home. I will post it tonight. Is your insurance co writing the vehicle off? Also, is the dash on the passenger side deformed at all where the air bag sits (the lip) toward the bottom, just curious. You will need a security torx bit if you don't have one allready. I am no expert but it may not be necessary to replace the front sensors if they are not damaged.
1999 Audi A8. No more SVX's for now.
Old 09-26-2005, 01:16 PM
ilsegretosvx
Wink
He is right once the AB detonates thats it, its has done its job. The sensors if both bags went off will have to replaced also. This is not a fun wiring job. I can tell you just from dismantling a SVX and having all the fenders off, that if you dont have to have your car down for a couple of days that if you dont think you need ABs ditch it and use the money for something else. BTW I'l give you a peek at my steering wheel. And yes it is a STi wheel.
