Old 11-04-2003, 10:31 AM
92Blacknessvx
Oil in my vacuum hoses?? HELP!!!
HEY, I JUST TOOK APART MY VACUUM HOSE ON TO FIND OUT THAT THERE WAS AROUND 3-4 OUNCES OF FRESH OIL IN MY MAIN VACUUM HOSE...IT COMING IN FROM THE ENGINE I KNOW THAT, BUT HOW??? I OPENED THE THROTTLE AND IT IS DIRTY AS HELL WITH TONS OF OIL IN IT. I WANT TO GET THIS FIXED BECAUSE THE OIL GOES FROM THE MAIN VACUUM HOSE TO ALL THE SMALLER ONES WHICH IS GOING ALL OVER THE PLACE...PLEASE SOMEONE HELP ME!!!
Old 11-04-2003, 11:59 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
By "Main" vacuum hose, are you talking about the PCV hose. If so, just change the PCV valve.
Now, are you the one with the loose manifold? If so, tightening it might help things a bit.
Once you've gotten the manifold tightened, and the PCV valve replaced, do a search on "throttle body cleaning" and find step by step instructions on cleaning the TB.
Randy Johnson
Mike Davis -- at Reading VI
Old 11-04-2003, 12:54 PM
92Blacknessvx
Umm...what does PCV stand for...and where is it, and how do I replace it...im pretty sure that it is fairly easy, but please help me out, thanks a lot.....I love these forums!!!!
Old 11-04-2003, 01:02 PM
Mr. Pockets's Avatar
Moderator
PCV stands for Positive Crankcase Ventilation. You can find a full description of the system here:
http://www.hastingsfilter.com/engine...tsb_94-2r.html
The PCV valve should be replaced regularly. It's inexpensive, but difficult to get to. Here's a diagram showing how the PCV valve attaches to the manifold. It's item number 2 on the diagram.
http://tinyurl.com/tncj
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-04-2003, 01:05 PM
92Blacknessvx
Thanks man! Im gonna try to get that taken care of....you can get that from Orielly right? Theyll probably have to speical order it though...
Old 11-04-2003, 01:21 PM
Aredubjay's Avatar
Actually, the PCV valve is quite common. They'll probably have it in stock. I bought my last one from Autozone. They're not that difficult to get. They're just difficult to install. Check the "How To" locker for instructions.
Randy Johnson
Old 11-04-2003, 09:14 PM
Invisible avatar
Question
Just curious - if the PVC valve is scuzzed enough to create idling problems, why hasn't the "check engine" light come on?
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 11-04-2003, 11:20 PM
Aredubjay's Avatar
Ron.
Beats me. Perhaps the problem didn't change the right values in the right sensors. One would also think the CE light would come on if too much air was entering through the manifold (ie loose screws), but, perhaps since it' s bypassing the MAF sensor, it doesn't register. I really don't know. Just thinking out loud. Kinda like when your tranny poops its pants, and it's "mechanical" you don't get a power light. Only if one of the electronically controlled components fail, will you get the "flash" and the codes.
Randy Johnson
Old 11-05-2003, 08:25 AM
Invisible avatar
Wink
[I really don't know. Just thinking out loud. Kinda like when your tranny poops its pants, and it's "mechanical" you don't get a power light. Only if one of the electronically controlled components fail, will you get the "flash" and the codes. [/B][/QUOTE]
Sorta' like worrying about box cutters & nail files, when it's easy to stow a nuclear device in the hold of a cargo plane.
What a country!
Ron.
'01 Miata SE - 79K
Old 11-05-2003, 08:29 AM
Aredubjay's Avatar
What a country!
Ron.
What I hated was the story about the 80 year old lady who was not allowed to board an airplane with her knitting needles. They were afraid she'd knit an Afghan.
Randy Johnson
