My engine burns a lot of oil...
Hi folks.
Sorry, but this will be a long post. Basic symptom: the oil comes out on the exhaustpipes. I suppose the valve seals gone south... but don't hesitate to correct me if I'm wrong. Anyway, I have a lot of questions since the car is hitting 200.000km and there should be some maintenance to do when the mechanics take off the valve cover for repair so here are my concerns: 1) since I'm gonna have the timing belt changed I was just wondering which idler pulley needs to be exchanged (I've found a timingbelt diagram in the How-to locker). Is it Idler or Idler No. 2 or maybe both? 2) is it possible that the lambda sonde will be affected by that massive amount of oil going/flowing thru the exhaust system? should I have that changed as well maybe? 3) when the spark plugs will be changed, also a good time to change the spark coils or forget it because they won't get worn out so easily? 4) I have a loud ticking noise which is pretty much in synchro with the RPM coming from the passenger side of the engine. Not with cold engine, only when it's warm. I just hope it's not the flexplate... ? 5) chances are I'm gonna need the full seal-set for the engine. Can someone give me the subaru part # of this seal set I cannot seem to find it on subarupart.com. Very appreciate it! I guess that's all for now. Thanks for any help and please don't say to sell the car - it's a white SVX so this is not an option ![]() |
l'm not a mechanic, but I've heard the coil packs are sturdy (and about $100 each!), so I wouldn't replace unless specifically diagnosed defective.
Good Luck! ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
I don't if it's the valve seals. It is most likely the rings. You should PM Mohrds (Doug) he had a similar problem.
If it is the valve stems seals, they are inside the double springs. The only way to get them off is to take the heads off so the springs can be compressed. The cam shafts have to come out to do this. The cam shafts can only come out when the engine is out of the car.
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
i heard coils go a lot more than $100 a piece, and they dont need to be replaced unless they break, which is rare.
on this car with this engine i would recommend making room to do such a thing as service cams. how you do it is your call.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
I am always up for a challenge.
considering what it was like to merely change the plugs, cams do not even register in my mind as accessible with the engine still in the bay. i cant imagine doing such a thing.
Thanks for all the info guys but I am still unsure that it's the valve seals. Is it for sure or the oil cloud on the rear bumper just above the exhaust pipes can be something else too?
RSK,
Oil in the exhaust and on rear bumper is either valve seals or piston rings. Unfortunately for you it is not a typical problem for an SVX - you will not be able to find much experience on this forum. Are you sure it is oil? Do you have to top up engine oil between the oil changes? How much and how often? The black stuff from exhaust can be unburnt carbon due to rich mixture (should not be too greasy though) Re lambda sonde it is called Oxygen Sensor here. You have two sensors in the car. They do not like to be dirty on outside - they have to breeze fresh air in order to function properly. A failed sensor will illuminate check engine light after 10-15 minutes of running. I suggest checking engine trouble codes before replacing these sensors. |
![]() The reason I'm asking this is because I have to buy a lot of stuff before the job gets done (oil pump, water pump, etc) but if it's the pistons, it just not worth all the trouble: I'm gonna dump the car and get another one. Got it for ridiculous money anyway and I definitely wanted to give it a shot. Quote:
Cheers, RSK |
Don't know how to help you further, but you should diagnose/solve this first before you spend any more money on this engine. Don't put a new timing belt or water pump or anything on it - it might be more economical to buy a used engine from a wrecker and put new pump/belt etc on it. There are some signs that might telltale whether its pistons or valve seals, but I don't know how reliable are they on SVX or flat boxer engines for that matter. Usually if you get a cloud of smoke when you rev engine after it has idled for a few minutes - its the valve seals. If you get smoke under heavy acceleration in gear - its piston rings, but I don't know how well this applies to Subaru engines. |
![]() Last edited by RSK; 10-29-2003 at 01:38 AM. |
