Old 10-25-2003, 05:00 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Angry "Simple" fix gone bad. GRRRRR
Did all the prep work to get the old, rusted, nasty power steering pump cooler out. Got the car up on the ramps, crawled under and went after the first bolt that held the passenger's side bracket. SNAP! The head snapped off. <Expletive Deleted> So, I went over to the other one. SNAP! <Multiple Expletives Deleted> Finally extracted the old cooler, but now, I'm stuck with the dilemma of how to get the rest of the bolts out of the bracket holes. They're rusted in badly (obviously). I've soaked them both with PB Blaster, but, there isn't enough of the bolt to get hold of with vice grips. Even if I completely remove the radiator, I don't think I can get grips on the inside of the bolts to turn them all the way through. There's not a lot of room to try to drill them out. Anybody know of an effective tool? After I sprayed the PB Blaster on them, I was able to get a punch on the end and tap them a few times and re-spray them, but, darn it, this is nuts! Not only that, but, they didn't supply new bolts with the cooler. Just new hoses & clamps (and the clamps are shoddy, by the way). I'm open to any suggestions. Right now, she's still on the ramps,since it started to rain, and I had to abandon the project. Hopefully I'll be able to finish up tomorrow.
Randy Johnson
Mike Davis -- at Reading VI
Old 10-25-2003, 05:08 PM
Craftsman bolt extractors worked well for me, but you do need to drill a hole in the bolt to work the extractor in (then you just manually twist the extractor and bolt out.) think you can get a drill in there with a small bit? have/borrow a right angle drill?
good luck!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-25-2003, 05:40 PM
Darn, I hate that when you start to do a simple job and it all goes south. One step forward and two steps back. Why does it always have to be so hard!
Old 10-25-2003, 09:13 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
You can do what I did and get rid of it all together, I went to a salvage yard and got a real power steering cooler from a Ford Explorer. It is a a smaller version of a B&M tranny cooler.I mounted it on the left side on front of the condenser and ran longer hoses to it.
You can see it on the left of the attached picture. It was pretty easy to do.
Old 10-25-2003, 09:45 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Nubs,
How much turning are you doing that you need a cooler from an Exploder?
Old 10-26-2003, 12:47 AM
Aredubjay's Avatar
That'd be great, Mike, but, I've already bought and paid for the stock cooler.
Randy Johnson
Old 10-26-2003, 12:49 AM
Aredubjay's Avatar
good luck!
I checked to see if I can get a drill in the space, and I can. But, I'll need to get a smaller bit than the smallest I have at the moment. Will be making a trip to Sears in the morning (Or, rather, THIS morning).
Randy Johnson
Old 10-26-2003, 05:57 AM
nubs's Avatar
Multiple Suby Owner
Originally posted by benebob
Nubs,
Not much really,I got if for nothing and when I was replacing my hoses I thought I would stick it in. I am sure it can't hurt.
Old 10-26-2003, 05:59 AM
check to see what size bit you'll need on the bolt extractor package - there are different size extractors depending on the size of the bolt, and they each require a specific size hole to be drilled.
Old 10-26-2003, 04:50 PM
svx_commuter's Avatar
I occasionally just take things apart and put them back together on the SVX with silicone on the threads to avoids these problems. Ah Randy, Hi you said that the PS cooler rotted away from rust. Right? How is that radiator and ac condensor doing? I broke the 10mm (bolt head size) that holds the fans in my 91 Legacy. But I had 4 bolts and broke only 2. @ is good enough. You do not have to use the same size bolt. Tap a new hole for a bigger bolt or if you can, try a bolt and nut.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
