Old 10-22-2003, 10:47 AM
svxsubaru1's Avatar
Rear diff removal?
How are you spose to get the rear diff out of the car i heard you can just unbolt the rear diff and pop off the rear half shafts. Is this how your spose to take it off? THANKS
Old 10-22-2003, 11:48 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: Rear diff removal?
Originally posted by svxsubaru1
How are you suppose to get the rear diff out of the car i heard you can just unbolt the rear diff and pop off the rear half shafts. Is this how your suppose to take it off? THANKS
Remove the exhaust system and driveshaft first.
Then I removed each side's rear suspension. I was planning to replace all the bushings anyway so it made sense to me to do that first. With the suspension loose, I could pull the axle out of the hub and lay the end of the axle on a clean mat. When both sides were disconnected, I removed the front diff mount which I believe has three bolts and removed the two rear nuts. Then I used a floor jack to slide the diff forward out of the mounts and lowered it out of the car.
Only after the assembly was out, did I separate the axles from the diff.
There are many ways to do it. This just happened to work best for me.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 10-22-2003, 11:59 AM
svxsubaru1's Avatar
yeah I already have the drive shaft and exhust out, becasue the tranny is out. Do you know if you can take the rear diff out with out messing with the rear suspension?
Old 10-22-2003, 01:11 PM
mohrds's Avatar
yeah I already have the drive shaft and exhaust out, because the tranny is out. Do you know if you can take the rear diff out with out messing with the rear suspension?
I would tend to doubt it. You'll at least have to loosen one side to get enough clearance to get the first axle out.
Those splined shafts are pretty long.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 10-22-2003, 04:37 PM
svxsubaru1's Avatar
Yeah thats what Ij was thinking, but i heard that you could on some subaru from some one.
