Old 10-17-2003, 10:17 AM
mbtoloczko's Avatar
sans SVX
stock front sway bar bushing dimensions
SVXRide asked me to post this:
total depth (incl lip): 1.15"
depth across the clamp area: 0.83"
height of center of hole from bottom of bushing: 1.25"
width across the clamp area: 1.35"
total width (incl lip): 1.67"
height in the clamp area: 1.87"
total height (incl lip): 2.17"
These measurements were taken with a caliper. Depth is defined as the dimension parallel to the axis of hole.
These measurements are off a nearly new bushing. The clamp compresses the bushing a fair amount in the height dimension. I would estimate about 0.13-0.18" of compression.
Mychailo
Visit my locker
Old 10-17-2003, 10:34 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Height of hole
Mychailo,
thanks for posting the dimensions! one question - is the "height of the hole from bottom of bushing" dimension to the bottom of the hole or the top of the hole? (i.e. does it include the hole diameter?)
thanks!
-Bill (now trying to figure out how he can get his urethane bushings to his machinist...)
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-17-2003, 11:17 AM
mbtoloczko's Avatar
sans SVX
Oops. Its to the center of the hole. I updated the description.
Mychailo
Visit my locker
